Old 03-18-2014, 07:20 AM   #1
1965 24' Tradewind
Renton , Washington
replace axles
I have a 1965 Tradewind. I'm wondering if I have to replace the axles? I jacked the trailer and the wheel dropped 3" and the arms are pointing down 10 or 15 degrees when sitting on the axles. I have been towing it all over the place and it tows nice..Is there any chance these axles are fine?
Thanks!
wildman is offline   Reply With Quote
Old 03-18-2014, 07:30 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I still have the original axles on my 61. While there are many good reasons to replace axles. I personally believe a lot of axles are changed that don't need to be.
If it tows well and you don't appear to be beating anything to death I would not be overly concerned about it.
If you have a gas light, how long the mantle lasts can be a good indicator of whats happening in the trailer when its moving. I have had them last an entire season
I expect I will get a lot of flack for saying that however
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 03-18-2014, 07:35 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Have someone tow you down a rough road while you are inside and evaluate if the ride is smooth
Old 03-18-2014, 08:29 AM   #4
Thanks!
Your describing axles that are very much OK.
Perhaps a previous owner replaced them.
Are the brakes 10" or 12" ?
Check the data plate that is on the axles and perhaps that would answer your questions further.
Old 03-18-2014, 08:53 AM   #5
1965 24' Tradewind
Renton , Washington
Thanks Rick I think that makes sense
Old 03-18-2014, 09:16 AM   #6
1981 31' Excella II
New Market , Alabama
I am with Andy on this one. I think they have been replaced already which almost never happens unless the PO spent some time here. There should be some ID plates on them. I think they are on the axle tube.
Perry
Old 03-18-2014, 09:16 AM   #7
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
I want to check my data plates, too. Where exactly on the axles are they located? Where on the axle tube, and do they have an exact date of manufacture on them?
youngpeck is offline   Reply With Quote
Old 03-18-2014, 10:27 AM   #8
There is a small metal plate tack welded to the square tube of each axle.
Old 03-18-2014, 11:32 AM   #9
1965 24' Tradewind
Renton , Washington
Ah you guys are the best! I never even thought about them already being replaced! See you on the road..
Thanks!
Old 03-18-2014, 04:26 PM   #10
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Lucky!!! That will save about $1400... Ahh, what to do w/ that extra money!!!
Cochese is offline   Reply With Quote
Old 03-18-2014, 05:26 PM   #11
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
You really don't have too
It is like riding in the back seat in a state that does not require back sweaters to wear seat belts you really don't have to wear the the belts they only help IF you are in an Accident! One of the PO's of our caravel kept the old axles. Nuff said
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 03-18-2014, 05:33 PM   #12
1966 17' Caravel
I have to replace the curb side panel for the wheel well and only because the frankenstine look just does not look good on a caravel, he saved 1100.00 and cost me 2200.00! Gotta love those cost savings.
Just my sob story
Cliff
Old 03-18-2014, 06:09 PM   #13
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I just got the email that my axles from Colin will be here Friday ! I have 2 weeks before my first music fest... Plenty of time( if they fit!!)
Old 03-18-2014, 06:51 PM   #14
1966 17' Caravel
They will
Cliff
Towing with Bad Axles CF Av8or Axles 15 02-11-2012 05:19 AM
Curved Axles?! ASNomads Axles 15 02-08-2012 03:02 PM
Axles Parallel With Frame? rwkrapfel Axles 11 02-02-2012 07:22 AM
Axles Inland RV Center, In Commercial Listings 0 10-01-2011 09:13 AM
