Old 11-19-2016, 01:20 PM   #1
Michael
Michael Meer's Avatar
1961 24' Tradewind
Kortenhoef , Noord Holland
replace axle
Hi There,
We buyed this Summer a 1961 Airstream Tradewind 24 and shipped her to Europe ( The Netherlands )
We want to swap the axle for a new one, but the questions is: Can the axle be remove under the Airstream , or do you have to open up the subfloor and unbolt the axle there? Every respons is helpfull!!
Michael an de Miranda
Michael Meer is offline   Reply With Quote
Old 11-19-2016, 01:42 PM   #2
1981 31' Excella II
New Market , Alabama
Right about that time period they went from a standard leaf spring axle to a rubber torsion spring axle. I am assuming yours is a torsion axle. Usually, there are two large bolts that bolt the axle to a mounting plate that is welded to the frame. You should be able to remove them from below.
Perry
Old 11-19-2016, 01:50 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
When torsion axles were first used, some were welded on and not bolted. You should check.
Bill
Just my personal opinion
Old 11-19-2016, 03:52 PM   #4
Michael
1961 24' Tradewind
Thanks Perry and Bill, for the quick respond, seen the bolts on the mounting plate, that probably the only connection. I will post tommorrow some picture from the axle, ( its nighttime overhere) Thanks appreciate for support
To Replace or Not to Replace that is the Question Redleger Water Heaters, Filters & Pumps 3 10-15-2016 07:38 PM
To Replace or Not to Replace 65air Towing, Tow Vehicles & Hitches 3 03-29-2013 12:58 PM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
2 replace decal or not to replace? nustreamer Clearcoat, Exterior Paint & Trim 1 07-15-2011 10:28 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
