05-24-2018, 08:40 PM
Boerne
Removing bolts for axles. 1991
I am having trouble breaking free the bolts holding the axles in place on my 1991 34ft excella. Presoaked the nut twice with penetrant. I've tried heating the nut with a propane torch and then removing with an impact wrench, and tried to put the end of the1/2" breaker bar on the top of a hydraulic jack and observed the bar flex but the nut will not budge. I've got a couple weeks to figure this out.
Any advice?
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley. 1600 Watts Solar/ 400Ah Lithium batteries
Tow With: 2006 Dodge 2500 Quad LB 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr, Bilstein Shocks, Ingalls balljoints.
05-24-2018, 09:17 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
I used a sawzall with a 18T metal blade, a few of them.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
05-24-2018, 09:52 PM
1979 23' Safari
1954 29' Liner
Orange
Or carefully with an acetylene wrench aka cutting torch.
Bill Kerfoot
Just my personal opinion
https://billbethsblog.blogspot.com/
05-25-2018, 09:14 AM
Boerne
Ok, I might have to resort to cutting the head off the bolt and hammering it through.
James B.
05-25-2018, 09:37 AM
1994 30' Excella
alexandria
, Kentucky
Borrow a 3/4" drive socket set and a cheater bar from a friend. You can get much more power/torque with the 3/4" drive.
Penetrant - I like AeroKroil - it is the best I have found so far. Spray the bolts down 2x times a day and let it soak for a day or so. http://www.kanolabs.com/penLub.html
I have heard that dry ice works well,
Nut splitter tool?
Sharp chisel and small sledge hammer
Sawzaw the nut off
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
05-25-2018, 09:55 PM
1999 34' Excella
Hillsboro
great advice here! A nut splitter will help.. the 3/4 breaker bar will help... a better 'impact' wrench (with impact socket) may help..
There is a Snap=On tool.. an 'inductor'.. which uses similar technology as the induction cooktops to heat a fastener.. look on Youtube! They exist!
I am sure they are 'cost prohibitive'.
A 'fire knife' (torch).. NO!!! too easy to mess up ...
I have 'center drilled' bolts before... but it is very difficult..
Now, PB blaster, Aerokoil.. are some good ones!!
With Fire Extingusher in hand.. and a "welding blanket" protecting the underbelly...
I would 'heat' the nut with the propane torch.. carefully.. not so hot the spray will ignite.. then spray with the PB or Aerokoil. When done properly, the spray will cause cooling and also 'pull' the liquid into the threads...
If things get too hot, use the heat gun... it won't get so hot as to flame the spray stuff.. unless you use them simultaneously. The advantage to the Propane torch is you can apply the hot part of the flame directly on the bolt...
Repeat the process on each bolt then come back to first and begin cycle again..
I saw some WD40 with an 'activator' in it.. and it seemed to melt away the rust.. I am gonna get some next time I need to bust a bolt.
If all else fails, or if it is more satisfying than fire (hard to imagine), Sawzall.
I used a Dremel tool to cut thru nuts frozen to shock absorbers several times... just cut as flush to the plate as possible... then knock out the bolt...
BTW.. make sure you have things properly supported.. PLEASE!! you have been REMINDED!
Peace and Blessings..
Channing
WBCCI# 30676
07-01-2018, 07:55 PM
1978 31' Excella 500
Beach
, North Dakota
i ordered a nut splitter from amazon for $23. Very hard to find one that would fit the 15/16" nuts locally.
