Old 06-16-2005, 10:17 AM   #15
1972 27' Overlander
Saline , Michigan
In my 72 rear bath I had some water leaking in from outside above the rear storage, I sealed with Vulcum, but water still gets in, maybe thru hing, water then makes its way to the black tank support.
How have others dealt with this?
I drilled a few holes in the belly pan, this seems to help drain the water that makes its way into the bumper storage.
Steve
loechli is offline   Reply With Quote
Old 06-16-2005, 12:41 PM   #16
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Water Leaking
Have you replaced the gasket on the rear compartment door?
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 06-16-2005, 01:10 PM   #17
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Steve
I've got the entire interior out of mine doing a 'Monty. Many things back there can leak. There is Vulkem sealant along the seams of the outer shell aluminum panels (on the inside, obviously). There are several small leaks where the Vulkem is beginning to age. Also, The power wires for the rear running lights leak in a couple of spots. These lights are riveted to the outer shell and a small hole is drilled and the wire inserted there. These holes and mounting rivets are sealed on the interior side with Velkem. The point is that the leak may be a long way from where you actually see the water.
Try the hose and a helper trick. Have a helper take a water hose and start at the bottom of the camper and work his way up (slowly) while you stand inside and try to find the leak. Sometimes it works, sometimes leaks can be hard to find. And sometimes (as in my case) you have multiple leaks. Good Luck and happy "hunting".
www.nesa.org
Air No. 6427
Old 06-16-2005, 01:58 PM   #18
1972 27' Overlander
Saline , Michigan
I have not replaced the gasket on the rear compartment door, but when doing a test with a hose it did not seem to be leaking that high.
It looks like it might be leaking on the hinge of the bumper compartment and running along the bottom.
has anyone come up with a way to keep bumper compartment dry as the hinge is not water tight?
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
Rear end reinforcing on a 62 Overlander Silverfly 1960 - 1964 Overlander 2 06-22-2004 08:21 PM
Rear End Separation Questions... Morning Dew Repairing/Replacing Floor &/or Frame 24 02-03-2004 10:22 PM
replacing rear area floor in 67 20 ft Globetrotter Coloradobus Repairing/Replacing Floor &/or Frame 0 07-06-2003 08:43 AM
Trailer weights davidz71 Our Community 6 05-28-2002 10:55 AM
