Old 03-05-2007, 03:41 PM   #1
Airstreamin' in Canada
Waterdown , Ontario
Realistic Axle replacement budget
I have a '73 Overlander on it's original axels.
Can you give me a rough estimate of how much new axels would cost, so I can budget for them?
Do I need to replace the whole axel and drums?
Michael
mlang905 is offline   Reply With Quote
Old 03-05-2007, 03:53 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The axle or axles in your case are one piece assembly each. The brakes would be seperate or in addtion to the axles. You can obtain the axles with out drums and braking pieces. And after 35 years of use you might want to reconsider that line of thinking. IE if the axles need replacement the braking assembly may need to be replaced too. Unless the brake assemblies have been replaced not too long ago.
I am going to defer the pricing answer to some one that has actually done this.
>>>>>>>>>>>>>>>>>Action
Old 03-05-2007, 04:25 PM   #3
1973 23' Safari
Maryville , Tennessee
Images: 13
I am about to go with new axles on a Tandem 73 Safari with 12 Inch Brakes, Shock Mounts, ETC...and it coming in at $1200 for both installed. Good luck.
kneal is offline   Reply With Quote
Old 03-05-2007, 04:37 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
That seems really reasonable...mind me askin' who's doin' it?
Old 03-05-2007, 08:47 PM   #5
1973 23' Safari
Images: 13
American Trailer Parts in Knoxville, TN. They recently did another members - Trevor Gardner - and it turned out great. http://www.airforums.com/forum...visgardne.html
Old 03-07-2007, 01:31 PM   #6
Waterdown , Ontario
What axels are they replacing with?
Old 03-07-2007, 08:31 PM   #7
1973 23' Safari
Images: 13
Dexter - 5200# cut down to 3000# with the 12 Inch Brakes and Shock Mounts....
Old 03-08-2007, 04:45 AM   #8
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Does this include new hubs, I'm guessing? And what type of lube option did you go with? Also, what sort of conversation did you have with the dealer on specifying your axles? I'm about to take mine in and am wondering if you worked with them on the mounting configuration, since it is backwards of the Henschens (though I know they will make them however you need them).
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 03-08-2007, 05:48 AM   #9
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Originally Posted by AYRSTRM2
the mounting configuration, since it is backwards of the Henschens .
Can you explain how you mean they are backwards?
'77 Sovereign Intl 31' CB
Old 03-12-2007, 11:03 PM   #10
1972 27' Overlander
Greenwood , South Carolina
The Dexter axles that I have seen have the brackets turned to the outside where the Airstreams (at least mine) are turned to the inside. Their order form shows that you can order reversed brackets. Also, mine will require the high mount. Their quote was $319 each plus state tax.
smead42 is offline   Reply With Quote
Old 03-12-2007, 11:16 PM   #11
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Dexter will make your axle (s) pretty close to the way you want them. Teh bolt holes might not line up with the axle mounting bracket, but drilling some new holes is not a big problem.
The key is to find a dealer that wants to do a good job for you, and is familiar with the DEXTER product line.
If in doubt, call Dexter's engineering department, and have them spec the product for you. Complete ( loaded) Dexter torsion axles run about $ 600.00 each. ( perhaps a little less than that.)
Or, buy Henschen axles for a closer fit.
Uwe
www.area63productions.com
Old 03-12-2007, 11:24 PM   #12
1972 27' Overlander
Dexter quoted me their #10 Torkflex 3200 lb. axles with electric brakes, high mounts, reversed brackets, and EZ grease hubs for $319. They emailed me the order form. Said they would take 10-14 days to supply. Did you get a $600 quote?
Old 03-12-2007, 11:35 PM   #13
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
I spec'd a downrated #11 axle, because of the 6 on5.5 wheel bolt pattern and the 12in brakes.
I believe their #10 axle has 10in brakes and 5-bolt wheel pattern. It is substantially cheaper.
Uwe
Old 03-12-2007, 11:41 PM   #14
1972 27' Overlander
Um, I did spec. the 6 lug 5.5 hub; and, I thought the original dia. brake drums. I will take another look at the drums.
SM
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Travel on 1 axle. Over59 Axles 6 04-18-2004 04:22 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
