Originally Posted by airhead
Greetings all,
Tomorrow I plan on putting my 60 Overlander on blocks in order to do a complete brake job, shocks and axel service. I have read some of the threads on the proper jacking location, there are some knowledgable AS'ers out there and I appreciate all your input. However, I would like to know where is the best placement for the blocks? I would like to block both sides so I can service all four wheels at once. I read a thread that stated to never jack or block the axels. Is this true? If so, where on the frame is the best location?
Also, does anyone have any good info. on converting to electric brakes. I'm in So. Cal. and am close to Inland RV. Or can I use any RV electric brake set up.
Any input would be helpful.
I plan on posting pics of our new 60 Overlander soon and some of the restoration we have done thus far.
Thanks a million
Airhead
You can jack up the airstream on the axle plate in between the wheels. Be careful, though, as you have leaf spring axles and yours might be different from what I have experienced. Jack up one side at a time, and place the jacks near the main frame rails, where the spring shackles mount.
If you hit the underbelly skin with your fist near the frame rails, you will get a slight crease indicating the outline of the rail. I used 2 HD jack stand behind the rear wheel frame section, and 2 on the tongue right where it comes out at the front.
I suggest 12" brakes, getting both backing plates and drums from the same manufacturer. The size of the bearing spindle is of paramount importance here...take exact measurements.
You might shop for complete axles, being easier to just bolt them on the leaf springs. Axles can be made to order and bought at many trailer supply places. You will need to add not only brake wiring, but also
12V to the tongue area for a breakaway switch ( required by law) Make sure and run a 12ga min 12V+ to the tongue from the coach battery for this. It splices in to the brake wiring. I suggest a 30A circuit breaker to protect this line. You can also run a future electric tongue jack from this power supply. Good Luck!!
