View Poll Results: Axle Replacement by year....
'60-'69 vintage - Replaced them 26 16.67%
'60-'69 vintage - Need to replace them 20 12.82%
'60-'69 vintage - My axle(s) are fine 12 7.69%
'70-'79 vintage - Replaced them 24 15.38%
'70-'79 vintage - Need to replace them 25 16.03%
'70-'79 vintage - My axle(s) are fine 32 20.51%
'80-'89 vintage - Replaced them 0 0%
'80-'89 vintage - Need to replace them 1 0.64%
'80-'89 vintage - My axle(s) are fine 10 6.41%
I don't know... 6 3.85%
Voters: 156. You may not vote on this poll
Old 08-05-2003, 08:50 AM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
POLL: Axle Replacement
OK, here is the definitive axle poll!
Just curious on number of people who are actually replacing them.
The 'I don't know' choice should be I don't know if they need to be replaced....
-Tim
theVAP - Airstream Podcast
Old 08-05-2003, 09:15 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I did mine. Replaced axles, one set of brake plates, shocks and new tires. Kept original bearings and hubs. Repacked bearings with Amsoil red synthetic grease.
The main reason I did mine was because the curb side was lower than the street side by an inch or two.
We have been out 5 times, since the axle replacement, longest trip was 225 miles one way.
Man, I'll tell you all. Stay out of OHIO!!!
Ohio's interstate system is in about as good as shape as the ALCAN highway was during the 50's. I really feel sorry for the truckers. If you need to test axles, springs, and shocks take I90 across Ohio. Gov. Taft should be hanging his head in shame. This is a big disgrace.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-05-2003, 11:31 AM   #3
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I don't know if mine needs replaced or not. I've looked underneith and the arm isn't into the negative yet, but the trailer is sitting pretty low (when you look at the wheelwell lip in relation to the wheel rim), It was pretty hard to wriggle the wheel out of there to do the bearings. Also, I think the trailer is getting a pretty rough ride judging from the cushions all out of place when we get where we're going. Also the panel got knocked loose from the aux heater fan, and the screw which holds the kitchen countertop to the wall keeps coming loose. Seems like after every trip I find more stuff shook loose in there. I don't even want to think about leaving stuff in the fridge again after our ride to Sisters.
I would think a new axle might not be too far in the future, lets say that.
Stephanie
Old 08-05-2003, 12:39 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Both of my trailers are nearing the time for axle replacement. Since the Minuet will be called upon for most travel for the next 16-months, it will receive the first new axle (if all goes well this Winter). The Overlander will likely get its new axles the following winter - - its axles are actually in worse condition, but the Argosy will be towed approximately 6,000 to 8,000 miles next summer (and it needs all of the help possible in the clearance area).
Kevin
Kevin D. Allen
AIR #827
Old 08-05-2003, 05:18 PM   #5
Morning Dew's Avatar
Send a message via AIM to Morning Dew
My 31' sovereign definately needs new axles, however i can't afford them. i'm 21 and still in school. i took the summer off, bought the airstream and toured the country. about half way through my trip i noticed the back end of my trailer sagging and i new i was in deep crap. the plan was to sell the trailer when i started school but i fell in love with it and i've been hit with the "restoration bug". oh well, time to get a part time job to pay for my new project.
Morning Dew is offline   Reply With Quote
Old 08-05-2003, 06:56 PM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Morning Dew, are you sure you need new axles, based on the rear end sagging, or are you talking about two seperate problems? Rear end separation fix is more complicated than just replacing axles. Please elaborate more so we can help you.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-05-2003, 07:12 PM   #7
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
This is one of those items I didn't know about until I found this fourm. Had I known it would have been a show stopper when I bought the AS. This puts the referb cost over the practical range. It's to late now !!!!!!!!!
I will have to replace before next spring.
Garry
Old 08-05-2003, 08:10 PM   #8
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Hey...why doesn't this poll include pre-'60 trailers? Just in case you were wondering, I replaced everything with the exception of leaf springs. Still contemplating adding shocks as none were original on my Trade Wind.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-05-2003, 09:16 PM   #9
Chas's Avatar
Images: 22
Re: POLL: Axle Replacement
Kevin
Kevin,
I was gonna tell you that the axles on your Overlander looked to be sagged out pretty well but figured InlandAndy would have told you first? Maybe he did?
My Minuet axle was probably the worst case ever, the axle arms were almost touching the bottom of the trailer.
Learned a valuable lesson on that one.
Chas
Chas is offline   Reply With Quote
Old 08-05-2003, 11:15 PM   #10
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
The website only allowed 10 items for the poll. I had to make a management decision
FF
-Tim
Old 08-06-2003, 06:39 AM   #11
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Not a problem Tim. Good poll.
FF
Old 08-06-2003, 11:21 AM   #12
I know they are two seperate problems but they are related. because of the spent axles i now have rear-end seperation. i just returned from my trip and havn't looked it over that much but my trailer, as a whole, sits very low. and the rear end definately sags about an inch or two.
Old 08-07-2003, 11:35 AM   #13
FireFighter's Avatar
bay city , Michigan
rear end seperation
hey can you elaborate on this rear end seperation issue and how to catch it before it is a huge problem. what am i to look for?
FireFighter is offline   Reply With Quote
Old 08-07-2003, 12:29 PM   #14
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Rear End Seperation
Stand on your rear bumper and wiggle it around. If you can see the gap widening between the bumper and body, then you have it. Creases in the coach body aluminum near the wheel wells is a tell tale sign also.
I was fortunate to buy a coach that had the factory/dealer upgrade with the tell-tale "Elephant Ears" on the rear of the unit.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Axle replacement finished uwe Axles 55 11-05-2011 10:21 AM
Axle Replacement ??? FC54 Axles 6 10-10-2003 05:01 PM
Axle replacement question-are they really worn out? oldvws Axles 1 12-30-2002 08:04 AM
