View Poll Results: Axle Replacement by year....
'60-'69 vintage - Replaced them 26 16.67%
'60-'69 vintage - Need to replace them 20 12.82%
'60-'69 vintage - My axle(s) are fine 12 7.69%
'70-'79 vintage - Replaced them 24 15.38%
'70-'79 vintage - Need to replace them 25 16.03%
'70-'79 vintage - My axle(s) are fine 32 20.51%
'80-'89 vintage - Replaced them 0 0%
'80-'89 vintage - Need to replace them 1 0.64%
'80-'89 vintage - My axle(s) are fine 10 6.41%
I don't know... 6 3.85%
Voters: 156. You may not vote on this poll
Old 01-30-2006, 03:39 PM   #43
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Axles are the backbone of your trailer
My axles have been replaced with Dexter Axles all new backing plates and drums and was switched from hydralic to electric
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 01-30-2006, 03:46 PM   #44
Originally Posted by 3isnotenough
How to KNOW you have a bad axle:...It is amazing how fast one can go from "fat, dumb, and happy" to "panicked" as the light dawns.
You may very well have a bad axle. But running gear imbalance will do the same things even if your axle is new.
So will towing with the wrong tongue weight or spring bars not matched to your tow vehicle.
joatmon is offline   Reply With Quote
Old 01-30-2006, 03:48 PM   #45
Originally Posted by davidh
.. and drums and was switched from hydralic to electric
Do you mean "switched from vacuum to electric"? I thought the latest fad was hydraulic.
Old 01-30-2006, 09:02 PM   #46
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Hydraulic trailer brakes are what most people are switching from to have electric brakes. when you apply your brakes the brake controler sends a signal to the hydraulic pump motor which was located front center of trailer, then starts to run to build hydraulic pressure to apply your trailer brakes, which then you could adjust amount of brake application at your brake controller, there was never vacuum on this modle..
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Axle replacement finished uwe Axles 55 11-05-2011 10:21 AM
Axle Replacement ??? FC54 Axles 6 10-10-2003 05:01 PM
Axle replacement question-are they really worn out? oldvws Axles 1 12-30-2002 08:04 AM
