View Poll Results: Axle Replacement by year....
'60-'69 vintage - Replaced them 26 16.67%
'60-'69 vintage - Need to replace them 20 12.82%
'60-'69 vintage - My axle(s) are fine 12 7.69%
'70-'79 vintage - Replaced them 24 15.38%
'70-'79 vintage - Need to replace them 25 16.03%
'70-'79 vintage - My axle(s) are fine 32 20.51%
'80-'89 vintage - Replaced them 0 0%
'80-'89 vintage - Need to replace them 1 0.64%
'80-'89 vintage - My axle(s) are fine 10 6.41%
I don't know... 6 3.85%
Voters: 156. You may not vote on this poll
Old 08-07-2003, 03:08 PM   #15
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Great Idea with the poll, Safari Tim!
Our '72 Sovereign needed the axles replaced. It's made a big difference in towability and ride quality. I have a lot more tire clearance. My wife was following the trailer in her truck on the way to and from the shop and noted that the trailer seemed to be bouncing a lot more going over bumps, whereas before, it was probably just bottoming out. There's some spring there now!
I disagree with Pick, however. The roads in Ohio are GREAT compared to PA and NJ. We just got back from the Statue of Liberty Rally. Those roads were awful! The toll roads are worse than the interstates, too! You'd think they'd put that money to good use and fix them up some. One lady's motorized wheelchair platform almost fell off the back of her motorhome on our caravan through PA and NJ.
We got the axles loaded with brakes. I found the castellated nuts were installed too tight and the brakes needed to be tightened immediately. So be sure and check those things right away if you get new ones.
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 08-07-2003, 08:55 PM   #16
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
When did airstream go to the rubber bushing axle ?
I would like to try to interpret Safari Tim's data as a predictor of when I should expect my 1987 to need new axles.
wingfoot321 is offline   Reply With Quote
Old 05-01-2005, 09:17 PM   #17
Somewhere , Indiana
Post Need New Axles?
For all you folks that need new axles, be sure to check out this thread:
The Minuet is at the Axle Doctor!
axleman is offline   Reply With Quote
Old 05-01-2005, 09:59 PM   #18
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
I don't think our '85 needs axles, 'cause they are at the same slightly upward angle as all other '80's era Airstreams I have seen (quite a few). I know the traditional wisdom communicated on the Forum is that if the angle is upward, the axles are shot. That probably does apply to the 60's & 70's models, but I question if it applies to the 80's, 90's and beyond. In addition to the fact that I have never seen an 80's Airstream with downward axle angles, and the fact that with upward axle angles 80's Airstreams show the correct amount of tire in the wheel weels, is the fact that the tongue heights listed on the Weights & Measures list on the Airstream company web site decreased from 19.5" to 18.75" between the 1980 and 1981 model years.
My hypothesis is that this tongue height decrease corresponded to an axle angle change. I am guessing that at this time Airstream changed from using 22.5 degree Henshen axles to the 10.0 degree axles. These numbers are the "no load" angles. According to the Henshen web site, for the 22.5 axle, the "normal" loaded position is 0 degress, while for the 10.0 degree axle, the normal" loaded position is upward 12.5 degrees. I'm not sure what load is used to determine the "normal" angle, but this seems to concur with what I have observed on 80's Airstreams.
And while I'm at it, since Thor bought Airstream in 1980, could this be one of the first changes they implemented? I assume the reason would be to lower the coach height, possibly to improve stability (lower center of mass) or to improve ease of entry.
I have never heard anyone else talk about this possible change and the impact it would have on determining whether 80's axles are OK or not. I think I am correct. What do you think?
Joe
WBCCI/VAC #6768
66Overlander is online now   Reply With Quote
Old 05-02-2005, 06:04 AM   #19
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
Rivet 'nuther rubber?
Originally Posted by Safari Tim
The 'I don't know' choice should be I don't know if they need to be replaced....
Hi Tim, can you please help out the "I don't know" people and review the indications that one's axle needs replacement. Is it just the resting angle of the swing arm?
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Old 05-02-2005, 03:30 PM   #20
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Steve,
Safari Tim has not been in this thread for almost 2 years.
>>>>>>>Action
Old 05-02-2005, 03:40 PM   #21
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Rivet
Steve
Steve, I can help you there.
Basically, if you crawl under your trailer, and look at the axle arms, and they seem to be pointing down, or level, you axle(s) is good. If the axle arms look like they are starting to point up, you need a new one(s).
If one side of the trailer is noticeably lower than the other side, you probably need an axle(s) A slight amount of height differential is normal, due to the difference in appliances and their weight side-to-side.
Old 05-02-2005, 03:49 PM   #22
sfixx's Avatar
1973 Argosy 20
Images: 12
Originally Posted by argosy20
Steve, I can help you there....
Thanks Terry, I knew it was an old thread but it beats starting new ones all the time. Apparently I'm okay for now with slightly down arms. We'll see how it does after a summer on it's wheels
Steve
If my axle droops more than the wheels are sunk into the mud does that make me a redneck
Old 05-02-2005, 04:18 PM   #23
Well Preserved
1993 21' Sovereign
Steve
I have seen another Argosy that had "good" axles, suddenly go to almost bad ones, just by starting to tow it around after it sat for an extended period. Hopefully yours will not be another one, axle are expensive.
Old 05-02-2005, 06:02 PM   #24
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Steve,
Most people use this article from Inland to help determine about their axel condition.
Steve
-Tim
theVAP - Airstream Podcast
Old 05-02-2005, 06:02 PM   #25
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Steve
Steve
Further axle info, great resource.
http://inlandrv.com/articles/dura-torque-axle-92001.htm
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 05-02-2005, 06:28 PM   #26
sfixx's Avatar
1973 Argosy 20
Images: 12
That just about covers it all. An excellent article Thanks alot
Steve
Old 05-04-2005, 04:10 PM   #27
Good questions. I've made the same observations with my 1981 Excella II. Does anyone have any input on these 80's axles and how they should be positioned? Thanks, P.
Peter&Denise is offline   Reply With Quote
Old 05-04-2005, 06:21 PM   #28
Coloradobus's Avatar
Peter and Denise, Following what you have posted above, the normal angle for a 22.5 degree axle is "0" degrees loaded, our Globetrotter is perfect. I just ordered a "NEW" Dexter axle with a 22.5 degree angle. Is it going to sit close to "0" degrees as well after we install it???? Like our original??:-((
Coloradobus is offline   Reply With Quote
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Axle replacement finished uwe Axles 55 11-05-2011 10:21 AM
Axle Replacement ??? FC54 Axles 6 10-10-2003 05:01 PM
Axle replacement question-are they really worn out? oldvws Axles 1 12-30-2002 08:04 AM
