03-30-2011, 05:11 PM
More than one rivet loose
Los Alamos
, New Mexico
Picking up my baby Monday
After a long winters nap, my baby awakes. I dropped here off last fall at AS of Spokane and told them no hurry. It was ready right around new years. Once I arrive we have about a days work installing Vent covers, the painted AC cover, additional solar panels and new WD hardware.
They installed a pair of new axles, new Kodiak brakes, Carlilie Electro-hydraulic actuator. The 100,000 mile axles had 80,000 miles on them. I did like the design of the Dexter brakes so they were replaced and Acti-brake went out of business.
It shall be good to see her behind the truck again.
Michelle TAC MT-0
Sarah, Snowball
03-30-2011, 05:32 PM
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
Ja' get the brakes separate from the axles? What size, 10"? What load bearing rating are your new axles?
Zep
03-30-2011, 06:23 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
I know what you mean about enjoying the view from your rear-view mirrors. We hooked up and took a short trip last weekend and I had a hard time focusing on the road.
Happy trails!
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
03-30-2011, 07:56 PM
Retired.
, At Large
Zep
Zep, you've been reading too many axle threads . The Kodiaks are generally disc replacements for 12".
03-30-2011, 08:29 PM
1973 23' Safari
1977 23' Safari
Palmer Lake
Au contraire, Master, too much $2Chuck....
03-31-2011, 05:41 AM
Retired.
, At Large
I avoid that stuff, though I do have a nice $3.99 box of red...
04-01-2011, 08:24 AM
Los Alamos
, New Mexico
Zep
Brakes were seperate from axles. Kodiak brakes, dexter axles.
The axles are 5000 lbs each. The trailer is 10,000 GVW.
The discs are 12".
Michelle TAC MT-0
Sarah, Snowball
04-06-2011, 08:13 PM
Los Alamos
, New Mexico
We completed the work mid-Tuesday. New solar panels are on. Vent covers are on. Painted Air Conditioner cover in on. New WD hardware was install after I bent a bracket and cam last year.
The replacement parts look different than the original. They changed the design. One my way home I sheared two bracket bolts. Fortunately I did not loose my WD bar. Last night one sheared and landed in the yard.
I am loosing faith in Reese Products.
Any one know of a hitch system that is not made in China?
Michelle TAC MT-0
Sarah, Snowball
04-06-2011, 08:41 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Been missing you Michelle. Where will you head for adventure now?
04-07-2011, 09:21 AM
Los Alamos
, New Mexico
Not much planned for this summer. Area 33 and a short trip to Glacier. I expect to make more Motorcycle trips this summer.
Michelle TAC MT-0
Sarah, Snowball
04-07-2011, 09:46 AM
1967 24' Tradewind
Greenville
, South Carolina
A/C cover
Like to see a pic of your painted A0c cover. What color did you paint it?
04-07-2011, 10:01 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
The Pro Pride is made in Michigan. We love ours and the Michigan economy could certainly use your patronage.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
04-07-2011, 10:11 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Greetings from the Florida Panhandle
Michelle,
Were your axles giving you any problem? If so, what do I need to look out for? Lucy is fast approaching the 80,000 mile mark.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
04-07-2011, 07:46 PM
Los Alamos
, New Mexico
Originally Posted by moosetags
Michelle,
Brian
The Axles were sagging a bit. Otherwise, they were fine. I opted to have them replaced before the "100,000 mile" bearings started to become a issue.
Michelle TAC MT-0
Sarah, Snowball
04-07-2011, 07:47 PM
Los Alamos
, New Mexico
I will certainly look into it.
Michelle TAC MT-0
Sarah, Snowball
04-07-2011, 07:56 PM
Los Alamos
, New Mexico
I will get one tomorrow.
Michelle TAC MT-0
Sarah, Snowball
04-08-2011, 08:26 PM
Los Alamos
, New Mexico
Originally Posted by SilverHoot
Like to see a pic of your painted A/c cover. What color did you paint it?
Here is the picture. I painted them two coats Krylon "Crome Aluminum".
They have two coats of primer, two coats of a shade of grey, and two coats of another color I forget. Finally the Chrome....
Michelle TAC MT-0
Sarah, Snowball
04-08-2011, 08:35 PM
2003 22' International CCD
Kiln
, Mississippi
Silver - really, why did you pick that color..... How about RED, BLUE, TAN, PURPLE.... Why is everyone on here so caught up in the silver theme.......
Looks good Michelle, get on the road, I live vicariously through peoples travels like yours.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
04-08-2011, 09:03 PM
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru
, New York
Which bolts sheared? Was it possibly the ones on the High Performance Dual Cam brackets? The reason I ask is because I recently installed one for a client, & two of the attachment bolt heads popped off about half an hour after installing them. When bolt heads typically shear off, the surface usually looks like it twisted off, however these bolts appeared to have been cast so the surface just looked broken. For whatever reason, Reese appears to be using very low quality hardware in a high stress application. These bolts appear to be made of "Chinesium". It might be a good idea to forward your concerns to Reese. I will be sending the bolts so they can do their own testing.
Colin
04-09-2011, 10:01 AM
Los Alamos
, New Mexico
Colin
I noticed they were cast as well. One showed a uniform break the other started at the thread, broke partially then completely.
I have talked to my distributor and they are forwarding my concerns to Reese.
They dual cam I have is the new version of the old one I had. They have the exact same part numbers.
I went out and purchased grade 8 bolts. I am going to try to get nuts on the inside of the frame.
My main concern is the cam looks cast as well. I wonder when they are going to break.
Michelle TAC MT-0
Sarah, Snowball
