Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 08-27-2009, 09:27 AM   #21
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Great information. Thanks Zep
SilverHoot is offline   Reply With Quote
Old 08-27-2009, 09:34 AM   #22
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
What's the cable for in the last install pic? Is that how you push/pull the axles into alignment?
Great install!
Marc
Old 08-27-2009, 09:41 AM   #23
SilverHoot's Avatar
1967 24' Tradewind
Originally Posted by Zeppelinium View Post
10". I ordered through Redneck Trailer Supply and they wouldn't deviate from the catalog. You have to get an axle at #3500 or more to get 12". The stopping power on four 10" drums is fine, no problem. The issue is, when is the last time the doofs at Dexter took a trailer down the west side of Loveland or Vail passes? I want the total energy capability of the bigger drums....
Zep
Yes, the 12" upgrade on the lighter axles is $107.00 per axle from Axis.
Old 08-27-2009, 11:09 AM   #24
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Originally Posted by 3Ms75Argosy View Post
What's the cable for in the last install pic? Is that how you push/pull the axles into alignment? ...
Yes, just a moderate amount of tension aft on the curb side and forward on the street side, to make sure the axle was up against the desired side of the slot. This is where the blair cutter was invaluable. By cutting a smooth, perfect 5/8" hole, the bolts can keep the axle in place with not even slight slippage. Hopefully, experience and miles will show even wear on the tires--both axles parallel to each other and normal to the trailer centerline.
Zep
Zep@Charmedquark.net
Old 08-27-2009, 02:04 PM   #25
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Great report, my axles for my Trade Wind are supposed to be in tomorrow. Your info will be a great help.
Question- Is that a new awning or just new fabric? Where did you get it. I need fabric for my 68 TW, but I can't find anything with the original looking vertical strips like in the picture.
Old 08-27-2009, 03:00 PM   #26
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Overlander axle project
Greetings 68 TWind!
Have your checked out the many stripe patterns available from Sunbrella -- it is the fabric utilized in ZipDee awnings. The blue pattern typically used with late model Airstreams is usually referred to as "Blue Fancy". You can find Sunbrella patterns at this link.
Good luck with your search!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 08-27-2009, 04:22 PM   #27
1973 23' Safari
1977 23' Safari
...Question- Is that a new awning or just new fabric? Where did you get it. I need fabric for my 68 TW, but I can't find anything with the original looking vertical strips like in the picture...
It's "new." Bought it through Lewster two years ago and just now got it installed. It's a standard Sunbrella fabric.
Zep
Old 08-28-2009, 07:01 AM   #28
SilverHoot's Avatar
1967 24' Tradewind
Zep,
I was looking at your great photos once more and was wondering if you would think it better to order the axles without any mounting holes at all. Don't know if that's possible. I most likely will be ordering mine today.
Old 08-28-2009, 08:02 AM   #29
1973 23' Safari
1977 23' Safari
Originally Posted by SilverHoot View Post
Zep,
I think that would be a great idea, but I think the mounting holes in the flanges/plates are punched out [not drilled], then the flange is bent to the standard shape. It might be possible to get them to omit the punching out of the holes, and just bend blanks, but I bet it delays the order for weeks, if it's even possible.
Zep
Old 08-28-2009, 08:49 AM   #30
SilverHoot's Avatar
1967 24' Tradewind
Leaving within the next 30 minutes for the Dexter dealer 178 miles away. Let you know if the it's possible to get the flange with no holes.
Old 08-29-2009, 03:50 PM   #31
SilverHoot's Avatar
1967 24' Tradewind
My brackets
Zep,
Here's a pic of my brackets. The guy said they were low profile, what you think? I did get reversed brackets.
Thanks, Michael
Old 08-29-2009, 04:44 PM   #32
1973 23' Safari
1977 23' Safari
Zep,
Thanks, Michael
Holy cow, you're right. They are low. Learn something new every day. I guess I'd check and see where your belly pan is. If there is an inch of space from the top of the axle slot up to the pan, then I'd still get the high hangars. But you're there and I'm not...
Zep
Old 08-29-2009, 05:45 PM   #33
Mexray's Avatar
1978 28' Ambassador
Morada , California
Last year, we replaced the axles on our 28 ft Ambassador with #3500 Henschen's with 12 inch electric brakes - replacing #3200 rated axles.
The new axles as received from InlandRV were exact fits, without any mod's needed - they bolted right in, and couldn't have been easier...
While jacking the trailer front and back may be an accepted routine, I'm not sure I'd want to do that on an older trailer - having to depend on all the rivets in the outer skin to keep things intact... Why temp fate with all that 'flexing' when you can easily lift the trailer as per the below routine...
I simply ran one axle up on blocks to then replace the other - supporting the trailer on it's normal axle loading points...then running the new axle up on blocks to replace the other - this method, when the AS remains hitched to the TV, safely elevates (providing you use suitable blocks, of course) the trailer so you can work under it without worrying about jacks, etc...
Our AS is a bit over 6K with all our stuff aboard, and rides so much better than with the old 'sagging' axles, it's hard to believe...
Ray & Pat; Morada, CA
Old 01-07-2013, 01:05 PM   #34
1973 23' Safari
1977 23' Safari
Estimating axle gross weight
Turns out I was a little shy in estimating what axle I should have ordered. The trailer weight is correct, but it turns out you DON'T want the axle max load to equal the trailer max weight. You want about 30% margin. These axles do OK for the Overlander, but I just did some research on new axles for a '73 Safari. The original axles were spec'd at 2600 lbs. The dry weight of the trailer on the wheels (not including tongue) is 3640 lbs. Max weight with water and stuff won't exceed 4500 lbs.
Current recommendations for this trailer is a pair of 3000 lb axles! That's a 33% margin. I thought it ought to be more like 2400 lbs, in order to get a soft ride. I caved and ordered 2800 lb axles.
Zep
Old 01-09-2013, 10:46 AM   #35
Zep
Zep.
The soft ride can be obtained several different ways, or a combination of them.
Reduced tire pressure (within reason).
Softer torsion bars.
Lighter suspended tow vehicle.
Balanced running gear.
Basically, the axle rating can be increased 10 to 15 percent, without having a negative impact on the softness of the trailer ride.
Of course, the huge unknown factor, is the "pay load" that some may choose to carry. That can become a huge variable.
So far, all your projects look great.
Keep up the great work.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-09-2013, 01:33 PM   #36
1972 31' Excella 500
Mount Vernon , Is For Lovers
Originally Posted by Inland RV Center, In View Post
Zep.
Thanks Zep,You are an invaluable asset to your "alloyed" allies!!
Sylver Slypr is offline   Reply With Quote
New Restoration Project, '72 Overlander surferstyler 1970 - 1973 Overlander 160 08-29-2013 06:28 PM
my new project - '60 Overlander garthbf 1960 - 1964 Overlander 11 07-18-2012 06:40 PM
'63 Overlander project starting GKP4570 General Repair Forum 6 02-02-2009 11:59 AM
Need advice on 62 Overlander project Marti General Interior Topics 4 03-04-2007 04:45 PM
Our '67 Overlander project robertandjenni General Interior Topics 16 05-14-2003 02:09 PM
