Old 03-01-2011, 08:32 AM   #43
1971 31' Sovereign
Greenville , Texas
Your kidding! Shocks absorb shock?
JKnight is offline   Reply With Quote
Old 03-01-2011, 08:39 AM   #44
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
Shocks absorb the energy stoping excessive bouncing on leaf and spring type suspension. Most trailer manufacturers do not use them on torsion axles as they are not needed. I am putting them on to keep original. Torsion axles do this by design but shocks will not hurt anything.
Get right or get left, and have a blessed day !
TAC OK-5
lahrfarm is offline   Reply With Quote
Old 03-01-2011, 12:38 PM   #45
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Wink Bad name for good thing
Originally Posted by JKnight View Post
Andy just curious, what purpose do the shocks serve on a torsion axle?
Shock absorbers are inappropriately named. In a suspension system, the shock absorbing is done by the springs or torsion bands in the case of an Airstream suspension.
The function of the shock absorbers is to dampen the springs, so that one bump won't cause a long roller coaster effect. Not surprisingly, you can observed what shocks are meant to correct, by watching an automobile with bad shocks go over a bumpy road.
As a matter of fact, what I consider to be shock is actually increased by shock absorbers. This is because the shock absorber impedes the spring's initial reaction to a bump.
Regards,
Ken
Old 03-01-2011, 03:35 PM   #46
Originally Posted by wasagachris View Post
Duh Andy if shock absorbers absorb shocks then I guess air conditioners condition the air,water pumps pump the water and water heaters heat the water etc. Pretty simple stuff then right? The name says it all.
Yes, but..........hot water heaters, don't heat hot water, never have, never will.
Andy hamburgers, are not made with ham.
So, sometimes, the name is confusing. Boxing gloves are "shock absorbing" too, but they don't fit too well on torsion axles.
axle
Henschen replacment axles JDL Axles 14 02-04-2011 01:41 AM
Who is still running on Original Axles? ALANSD Axles 18 01-18-2011 06:18 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
