Old 02-25-2011, 08:06 PM   #29
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
A non-gas non-air shock is designed to use gravity for the fluid internally. Position a vertical shock in a non-verticle or inverted position and it will not operate corectly. Like putting a verticle shock in a mostly horizontal position. It will look pretty and not do much movement dampening. (A shock absorber's only function)
And with new torsion axles not sure you will notice much difference with or with out a shock. So I have been told.
>>>>>>>>>Action
Old 02-25-2011, 09:08 PM   #30
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Lahrfarm,
I took an original shock (while replacing the axle) measured both the compressed length and the extended length. I took this info to NAPA,they have a book with all these specs and purchased two.
Tim
Beaker63 is offline   Reply With Quote
Old 02-25-2011, 09:12 PM   #31
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by Beaker63 View Post
Lahrfarm,
Tim
That works well for pre-'67 units.
>>>>>>>>>>>Action
Old 02-25-2011, 10:03 PM   #32
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
OK so the non gas shock will not work correctly horizontal. The Monroe gasmatic is a gas shock, I would guess by the name, so would'nt it likely work? Are any modern shocks "non gas"?
lahrfarm is offline   Reply With Quote
Old 02-25-2011, 10:37 PM   #33
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You have a horizontal shock for your trailer. The internal valving is different to accomodate the unique mounting of this shock.The only source that I am aware of for that shock is an Airstream dealer. This design was created by Airstream to save interior space.
1966 and older units (like Tim's) have a vertical mounted shock. Get the dimensions and mounting correct and most traditional shocks will work. I used NAPA as well as a source for my '66 Overlander.
>>>>>>>>>>>>>>Action
Old 02-26-2011, 08:47 AM   #34
Why take a risk with a product that your not sure of?
Certainly, the OEM shocks are cheap enough from several dealers below $30.00 each.
Old 02-26-2011, 09:36 AM   #35
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
I admit my brain does'nt completely understand the engeneering or buy it. I will however go with the experience represented on this forum and buy OEM shocks. They're all the same price. My dad always said dont ask the question if you wont accept an answere.
Old 02-26-2011, 11:40 AM   #36
Great choice.
Old 02-28-2011, 06:15 PM   #37
1971 31' Sovereign
Greenville , Texas
What angle did you order your axles 22.5 or 35 and how many lbs as well?
JKnight is offline   Reply With Quote
Old 02-28-2011, 06:40 PM   #38
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
3500# 22.5
Old 02-28-2011, 08:12 PM   #39
1971 31' Sovereign
Greenville , Texas
Thanks, I am having my made at north Texas running gear in Rockwall TX.
Old 02-28-2011, 08:14 PM   #40
1971 31' Sovereign
Greenville , Texas
Andy just curious, what purpose do the shocks serve on a torsion axle?
Old 02-28-2011, 10:29 PM   #41
They add additional shock absorbing, as their name implies.
Old 03-01-2011, 06:25 AM   #42
x
XXXX , XXXX
Duh Andy if shock absorbers absorb shocks then I guess air conditioners condition the air,water pumps pump the water and water heaters heat the water etc. Pretty simple stuff then right? The name says it all.
wasagachris is offline   Reply With Quote
axle
Henschen replacment axles JDL Axles 14 02-04-2011 01:41 AM
Who is still running on Original Axles? ALANSD Axles 18 01-18-2011 06:18 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
