Old 02-25-2011, 09:55 AM   #15
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
Thanks Top, I will probably put them on, I've gone this far might as well finish. Oriely auto has them local, that was a surprise!
lahrfarm is offline   Reply With Quote
Old 02-25-2011, 10:23 AM   #16
The correct part number for the Airstream horizontal shocks is 0220003.
Use caution when using a shock that does not have a known stiffness, as one that is too stiff could cause a shock beacket to shear off.
When in doubt, using the OEM part, puts you back to original, safely.
Old 02-25-2011, 11:20 AM   #17
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
There is no doubt. Those are the correct Monroe gasmatic shocks. I got that number from Colin Hyde. An Airstream number is just a number. Since Airstream doesn't manufacture shocks that I'm aware of, I'm sure it's just a number that will cross reference to a Monroe, Bilstein or KYB part number.
Lance
Top is offline   Reply With Quote
Old 02-25-2011, 12:06 PM   #18
Airstream uses a Gabriel shock.
Many non Airstream dealers, use all kinds of different products, since they cannot purchase from Airstream as a dealer.
They may or may not be using the correct replacement part.
Old 02-25-2011, 01:49 PM   #19
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
I dont believe I've ever heard of a funcioning shock being so stiff it could shear a bolt that is the correct size for that shocks collar. I know Monroe is a good product, and I'm sure both brands will perform well. My old ones are solid as a rock, I'm sure this will be better!
Old 02-25-2011, 01:58 PM   #20
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
I will disagree with Monroe being a good shock maybe a few years back (more then 5yrs) but Now there cheap and not worth the trouble. I have had to replace several of there shocks that were less then a year old and under 10k miles on them (automotive)
if you buy them keep your receipt you will most likely need to warranty at least one of them.
osolow is offline   Reply With Quote
Old 02-25-2011, 02:14 PM   #21
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
I believe you, but I dont think I've ever purchased a "bad" shock of any brand. Gabriel and Monroe are making most of the different brands with different paint and boxes. They are like alternators, I toured a local place called Unit Parts in Edmond. Unit parts boxes alternators for ten or so brands. They put the same alternators in different boxes, and everyone says one is better than the other at the parts house. There just are'nt the many manufacturers.
Old 02-25-2011, 06:21 PM   #22
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I don't believe I've ever heard of a functioning shock being so stiff it could shear a bolt that is the correct size for that shocks collar.
The only time I've seen that happen is when someone put air shocks on a car, and inflated the shocks to the max. Both upper shock bolts got torn out of their housing, and it was no wonder, since there was essentially zero "give" with that much pressure. Regular Monroe Matic or Gas Matic RV should be fine. I have put Monroe shocks on several Airstream and Argosy trailers over the years, and have yet to see a mounting bolt broken off by one.
Old 02-25-2011, 07:03 PM   #23
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I looked at my old shocks this afternoon. They were the original shocks installed when the trailer was built. Three were seeping fluid. The one that wasn't seeping fluid was nearly impossible to move. Here is what is stamped on them;
Pliacell 341-71 V BOTTOM V
4975425
Delco Products Dayton, Ohio USA
Since it is clearly stamped with V BOTTOM V I doubt it to be a horizontal shock. I guess I'll stop by the Airstream dealer next week and have a look at a new one. I wonder how much Penske racing would charge to put one Airstream shock and one Monroe on the shock dyno and do some side by side comparison....
Lance
Old 02-25-2011, 07:06 PM   #24
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
That I can agree with!
Old 02-25-2011, 07:40 PM   #25
Well Preserved
1993 21' Sovereign
Hmmm... Terry Labonte owns an RV dealership just down the street from my apartment. Maybe they'll do the same--if they have a shock dyno laying around... It would be interesting to get two sets of independent results.
Old 02-25-2011, 07:41 PM   #26
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
What can you agree with?
Lance
Old 02-25-2011, 07:56 PM   #27
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
I was agreeing with the air shock pumped up to max. I guess I'd have to talk to an engineer on the rest of it. The way I see a shock, it is a sealed unit. If you turn it on its side or upside down it will not spill. When a shock of any kind leaks it has failed. I cant grasp that the position of the shock has anything to do with this. That would be like saying a hydraulic cylinder will leak if you use it on its side. I dont know, but I think trailer shocks are just trailer shocks.
Old 02-25-2011, 08:02 PM   #28
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Ok I see.
Lance
axle
Henschen replacment axles JDL Axles 14 02-04-2011 01:41 AM
Who is still running on Original Axles? ALANSD Axles 18 01-18-2011 06:18 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
