Old 10-11-2006, 10:48 AM   #1
McLogger's Avatar
Columbia , South Carolina
Some great info! Thank you again to this forum it is nice to have other people out there you can connect with that have the same interests that you have.
FYI, I do have a slight axel issue and I have spoke to Andy as well as a local guy that I do a lot with (the local guys Henschen quote is cheaper). I figured I would double check the tires while I was working on the axel issue. Sooooo short of having LT tires I am on the right track. I have found these 7:00 15 tires at a number of places, can any one suggest a brand to use or maybe not to use and why??????
Happy Camping
McLogger, AIR # 16452
McLogger is offline   Reply With Quote
Old 10-11-2006, 12:20 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
So asking that question may open a long discussion. And it has been discussed many time before so you may want to do a search.
I personally do not have a brand preference. I trust the manufactures specs and very very very frequently inspect the tires.
When the trailer is stored - I cover the tires and take some weight off the axle/tires by jacking it up and placing on stands. (Most of my trailer's life will be spent in a non-use state, so this is where I make sure the tires are filled and covered. The sun kills. And in my neck of the woods, the sun rules.)
When in use the tires will always have max air pressure.
>>>>>>>>>>>>>Action
Action is online now   Reply With Quote
Old 10-11-2006, 12:43 PM   #3
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Tell Us More, Please!...
We were under the impression that Inland RV has exclusive rights to sell Henschen axles (Or, at least I was under that impression). Tell us more about "the local guys" and the deal you can get from them.
As for tires, your Airstream is a travel trailer. I believe travel trailers should have "Special Trailer (ST)" tires. Now let the fun begin...
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-11-2006, 01:45 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Ken,
Indland RV has an exclusive in A/S axles for a certain year and prior. I believe the cut is like 1980 or 1981. Not totally sure on that. Henschen axles post that date can be ordered from dealers or other sources. I believe that this is because there was an axle design change around that time and Henschen didn't really want to deal with small orders for that older design. Just some what of a guess. The local dealer will not likely be able to get the pre-that date axle.
Also this thread is dealing with two subjects at the same time. It will be difficult for readers to get the info if you guys keep this thread going in tow directions. I would suggest starting a new thread if you want to discuss axles and tires brands. Let me know if you need help doing this.
>>>>>>>>>>>>Action
Old 10-11-2006, 02:37 PM   #5
Originally Posted by Action
Ken,
Inland RV has an exclusive in A/S axles for a certain year and prior. I believe the cut is like 1980 or 1981. Not totally sure on that. Henschen axles post that date can be ordered from dealers or other sources. I believe that this is because there was an axle design change around that time and Henschen didn't really want to deal with small orders for that older design. Just some what of a guess. The local dealer will not likely be able to get the pre-that date axle.
>>>>>>>>>>>>Action
Our contract with Henschen and Airstream gives us exclusive distribution rights for 20 year and older axles.
Therefore at this point, we distribute all Airstream and Argosy trailer and motorhome tag axles from 1986 and prior.
There have not been any design changes that have given reason for this agreement, or the years involved.
On occassion a local dealer may make an attempt to place an order with Henschen or Airstream. That order will be rejected once it hits production scheduling at Henschen.
Henschen simply can no longer accept retail trade, as it quickly becomes counterproductive to intermingle those orders with a huge production line method of manufacturing.
Old 10-21-2006, 03:03 PM   #6
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Axles for '69 Sovereign
As the sole distributor for Henchin axles, I guess you would be the one to ask. My '69 Sovereign's torsion bars sit at about Zero and will need to be replaced soon. Do you stock the axles for it? or do they have to be ordered? What is the correct axle load range? How much are the axles and how much is installation? It looks like just a few bolts so I might be able to do the install myself. What would be shipping cost to Amarillo, TX 79178. Can they be drop shipped? from the mfg?
Should I carry this conversion on off forum?
thinks, bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 10-21-2006, 06:02 PM   #7
thinks, bill b.
We have a large assortment of axles in stock. We also have axles drop shipped from Ohio.
In your case, the freight would probably be a littles cheaper from Ohio.
Upgrading to a higher weight capacity and/or changing the starting angle, is done at no additional charge.
We can answer your other questions in detail should you choose to call us.
"Shield" Brand Tires?? Jason1101 Tires 3 08-18-2009 06:30 PM
Cousin's brand new SOB.... Cedars Off Topic Forum 4 10-08-2005 08:02 AM
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 05:31 PM
Brand new to this; need logistics advice 4521red Our Community 21 01-01-2003 09:07 AM
Need spring load clips for water heater door 68 GT. Jim Clark Water Heaters, Filters & Pumps 4 05-09-2002 07:39 AM
