Old 08-19-2011, 09:38 AM   #1
Intrepid's Avatar
Plymouth Meeting , Pennsylvania
Number of Axles AS Website
At the AS Website, The Flying Cloud is pictured with one axle. Is one axle standard regardless of the length of this model? I'm some time away from a purchase, but the FC 25 FB is an early favorite. I had a utility trailer with one axle and it waved around a bit so I added a second. Wow what a difference.
I didn't see it on the AS website specifications any mention of the number of axles at the different lengths. Is there some point at which two axles are always used on the AirStreams? Anyone know?
Intrepid is offline   Reply With Quote
Old 08-19-2011, 10:01 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The single-axle trailers are just the shorter lengths. I know the 23FB is dual axle, I think the other 23' floorplan is as well, and all the longer models are dual axle.
David
Old 08-19-2011, 10:03 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have the 20' trailer pictured on the Flying Cloud website and I can assure you it doesn't wave around. Additional axles are put on to carry the heavier loads of larger trailers. Presently Airstream Sport models and 16', 19', and 20' models are light enough to use single axles, as determined by Airstream engineers. The number of axles is not an option.
doug k
Old 08-19-2011, 10:16 AM   #4
dkottum's Avatar
Regarding the utility trailer, adding the axle may have had the effect of shifting more load to the tongue, which is usually the cure for waving around, unless the trailer tongue is too short.
doug k
Website Campground Specials - Save MONEY Foiled Again On The Road... 0 05-13-2011 09:06 AM
