Old 07-19-2005, 06:21 AM   #1
Not the bearing I expected
So I bought a 1960 Overlander & was giving the running gear the once over to make it roadworthy. I did a search & found out what bearings it should have, but it doesn't. The front axle has electric brakes but the rear is hydraulic. When I pulled the rear hub I found that the outer bearing was a LM 67048. I expected the inner bearing to be a 25580 but instead I got a 25577. The measurements are very close but the inner diameter is different. The grease seal was all metal & very heavy duty. The parts guys all say they never saw anything like it. So my questions-
Are the hydraulic brake axles set up differently than the electric?
And where does one find one of these grease seals? A part number would be very helpful.
Brian
Miller is offline   Reply With Quote
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 05:50 AM
Synthetic Wheel Bearing Grease Pick Axles 4 11-24-2002 08:18 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
