Old 06-13-2011, 01:34 PM   #1
1963 16' Bambi
Delaware City , Delaware
Noise (from axle?)
Hi, folks. Just getting our 'new' 1961 Bambi on the road for the first time.
Hooked up today and took a few laps around town. There was a nasty metal-on-metal sounds coming from what sounded like the axle. It started as soon as the trailer started moving and did not get louder or quieter, nor did it change pitch, when the brakes were applied.
Found this thread, which gave me some clues. (http://www.airforums.com/forums/f439...els-28533.html)
Gonna have a local mechanic look at it, but does anyone have any hunches?
Thanks. ... Deldog
Deldog is offline   Reply With Quote
Old 06-13-2011, 03:01 PM   #2
Kevin245's Avatar
Originally Posted by Deldog View Post
...There was a nasty metal-on-metal sounds coming from what sounded like the axle. It started as soon as the trailer started moving and did not get louder or quieter, nor did it change pitch, when the brakes were applied.... Gonna have a local mechanic look at it, but does anyone have any hunches?
Thanks. ... Deldog
Hey Deldog,
"Nasty" is generally not good. Wheel/hub area sounds can be caused by a number of conditions. Some are self correcting, while others are not.
If the rig has been sitting for a period it is common to have some flash rust on the drums/disks that doesn't sound all that great but goes away after a few brake applications.
My first guess would be bearing failure. This condition is not self healing and usually leads to catastrophic failure if not corrected. Spindle and or hub damage are also an issue.
It could be number of things but as a minimum I would get it checked out sooner rather than later.
If you have the means, raise each wheel off the ground and spin them with your hand. If you hear noises, grip the tire at the 3:00 and 9:00 o'clock positions then wiggle the tire gently back and forth (press with your left hand while pulling with your right hand) to check play. A little "In and Out" movement is normal, but any "wobble" is usually a bearing condition signal and cause for concern.
I had a "Oh My" moment a year or so ago myself.
http://www.airforums.com/forums/f437...light=bearings
On a lighter note I've also had hub grease caps come loose then rattle around inside the hubcap. A lot of clanging and banding, but no grinding. So popping the hubcaps off may yield a cause as well.
Wishing you the best,
Kevin
Eleanor Roosevelt
Old 06-13-2011, 03:04 PM   #3
1963 16' Bambi
Thanks for the advice, Kevin. I really appreciate it. I'll keep you posted on what I discover.
Old 06-13-2011, 03:23 PM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
It is not uncommon for a broken brake spring to be loose inside the hub also. I would expect some variation in noise with speed, but perhaps not.
It is not difficult to pull the hub and see what falls out.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-13-2011, 03:33 PM   #5
1973 25' Tradewind
1964 19' Globetrotter
Centerville , Utah
Heard similar noise from one of my wheels this weekend when replacing all 4 tires. Pulled the hub off...out fell the broken brake spring and adjuster. A $12 fix. Fairly easy to replace. Hope it's something that simple for you. Good luck.
tclay
Stormy Weather is offline   Reply With Quote
Old 06-13-2011, 09:30 PM   #6
1963 16' Bambi
Thanks, guys. I'll check that. Really appreciate your help. So eager to get this baby through inspection and start camping.
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
