Old 07-02-2016, 06:31 AM   #1
wildwoodrver's Avatar
2012 30' International
Pleasant Hill , The Golden State
New sway...alignment?
We are experiencing sway for the first time after 15,000 miles on our 2012 International 30.
Presently on a trip through Nebraska, South and N. Dakota, Montana, Idaho, OR and WA.
We did scuff the curb side (slightly?) just before noticing the swaying. So bad I won't let my wife drive!
Have adjusted our Reese sway control hitch and will be installing a Hensley Arrow next week.
Can alignment cause the swaying?
If so, any recommendations on having alignment checked in states mentioned?Only place I've used on previous AS is in Tacoma, which was excellent.
Maybe an idea how I can check alignment myself?
As always, thanks in advance for suggestions.
2012 International Serenity, 30
Reese Trunnion Weight Dist. Hitch
2005 GMC Yukon XL, Tekonsha P3
Reese Tow Beast hitch
Quadrasteer - Autoride
wildwoodrver is offline   Reply With Quote
Old 07-02-2016, 06:36 AM   #2
Gainesville , Florida
How about tire pressures? Does the suspension look okay? The Hensley will help and anything wrong should become apparent as you mount it. Is everything tight on the hitch now? Good luck, be careful.
Old 07-02-2016, 10:40 AM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Checking tire pressures is a good suggestion.
A quick and easy check of TOE IN can be done with a long enough string. Tape the string to the front tire and pull back to the rear. For zero toe on the rear axle the string will touch the front and rear tire bulge of the rear tire at the same time when the string is pulled back. If not there is some toe in or toe out. Reverse the process for the front tire.
Two things It is a bit crude and inaccuracies are possible.
One would need to know the spec. I would assume since there are no driving axles the spec sight be zero.
>>>>>>>>Action
Old 07-02-2016, 03:21 PM   #4
Tire pressure fine...good starting point. Use TPM system. One more bolt on hitch to tighten. We leave tomorrow. It seemed a little better after I adjusted the hitch, but still felt new sway.
Old 07-04-2016, 04:10 PM   #5
Update!
Discovered a lot of play in my hitch receiver so will try to find a welder to change out the insert Reese uses or just weld in some spacers.
Stay tuned!
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
To sway or not to sway? cojer 1966-68 Caravel 11 03-15-2011 03:23 PM
67 Caravel Help: to sway or not to sway vonzellen Hitches, Couplers & Balls 15 01-26-2011 05:07 PM
to sway or not to sway... rayandre Hitches, Couplers & Balls 9 12-01-2010 06:52 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
