Old 03-17-2003, 08:10 AM   #1
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
New Springs for the old gal.
Well our A/S predates the torsion axles and has conventional springs. The bushings are shot. I have some concern about 43 year old rusty springs as well. Wouldn't mind the trailer sitting a little higher to help rear end clearence.
My problem is where to find the correct springs and bushings for a camper that should be about 4,000 lb traveling down the road. Anybody replaced a set in the past that can point me at a supplier? How much more rating should I add in for the weigt distribution hitch will put on the,? My understanding is the hitch shifts the weight back to the trailer. I don't want it too stiff and start pounding the camper but I can see how I could easily get too soft as well.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 03-17-2003, 09:32 AM   #2
LOST , Hawaii
How about a trailer place. If you have eye to eye dimension, they should be able to set you up. You might even be able to get some choice in arch for clearance.
John
74Argosy24MH is offline   Reply With Quote
Old 03-17-2003, 10:15 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Be careful as to how high it raises the trailer up. An inch or so migh be great, but more than that could change the center of gravity when you turn. The weight bars could help keep it stable, but too high is just as bad as too low.
Eric
Old 03-17-2003, 11:40 AM   #4
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Eric
I'm looking for about 2.5-3 inches. One inch is just the wore out bushings alone. They are pretty beat up and I figure they are not helping the stability when towing.
I figure I have sagged at least another inch. Knowing that I'm lookig for about 1 inch over what it was 40 years ago. LOL
1959 22' Caravanner
Atlanta, GA
Old 03-18-2003, 09:05 AM   #5
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Anybody else? I'm really trying to figure out what weight of spring to look for. If I have to I know of companmies that can make them if I give them the weight it needs to support.
1959 22' Caravanner
Atlanta, GA
Old 03-18-2003, 12:06 PM   #6
dmreilly10000's Avatar
1953 25' Cruiser
Brandon (near reservoir) , Mississippi
Images: 14
You should try to find a company that rebuilds springs.
I once had a Jeep CJ 5 that had worn out springs. I found a place here in Jackson Miss. that did nothing but build/rebuild leaf springs, mostly for large trucks.
They re-tempered the old leafs and added 1 more leaf to those. They put in new bushing in the ends also.
I have a 1953 Cruiser with leaf springs and will probably someday want to have them rebuilt.
Hope this helps.
dmreilly10000 is offline   Reply With Quote
10 gal in a 6 gal Hole aviontt Water Heaters, Filters & Pumps 18 12-19-2003 06:23 PM
Leaf springs markdoane Axles 2 09-27-2003 11:26 AM
Leaf Springs ALANSD Airstream Motorhome Forums 7 09-26-2003 11:55 AM
Mystic Springs 2003 rally!! thenewkid64 Forum Rallies & Meet Ups 41 04-02-2003 04:52 PM
Brake springs. niftypkg Brakes & Brake Controllers 2 05-10-2002 07:01 PM
