Old 12-27-2003, 10:37 PM   #1
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
new products at Dexter
was surfing, and discovered that dexter axle is offering disc brake retrofit kits in three sizes.
there are some other interesting things at the dexter site including a hydralic booster unit for disc brakes.
http://www.dexteraxle.com/home
john
you call them ferrets, i call them weasels.
Old 12-28-2003, 08:04 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I don't suppose these could be mounted to a '96 Caprice that currently has large rear drums........
Old 12-28-2003, 10:33 AM   #3
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
try junkyarding a set of disc's off a new Silverado. My bet is it would pretty well be a bolt on. If not check with
http://www.azkickin.com/ They could probably make a set that would use off the shelf parts. I have their kit on my 75 Jimmy. Just need to find a rotor with the correct bolt pattern. Might be able to use a 2wd top hat for the truck if no then need to find a solid axle 4x4 that has same bolt patern and it can be made to work.
Here is a write up I did. Using their product. They recently changed names after their Aerospace machine buisness got slow. Tell Bill or Bill Jr that "Grim" said to call if you deal with them.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Dexter stands behind their products! Aviator Brakes & Brake Controllers 1 09-13-2012 10:14 AM
Aistream anounces several new products.... crazylev Our Community 0 07-01-2005 11:34 AM
Fortune Mag's best products of 2004 Silvertwinkie Our Community 2 12-03-2004 08:49 AM
Solar products nwclassic Generators & Solar Power 4 07-09-2004 06:06 PM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 10:00 PM
