Old 04-11-2013, 12:50 PM   #1
100ProofDera's Avatar
1968 26' Overlander
Sewell , New Jersey
New Dexter Axle Installation Questions
I just received new axles for my 1968 Overlander, which I ordered through Island RV. I got the shock mounts welded on and got the first axle off. I thought the new axles where supposed to be an easy swap, but it doesn't appear that the new upgraded axles will slide into the cutout on the axle mounting plates. The old axles are 2.5 inches wide and the new ones are 3 inches. Do I cut the opening bigger?
100ProofDera is offline   Reply With Quote
Old 04-11-2013, 12:56 PM   #2
1968 26' Overlander
Sewell , New Jersey
Old 04-11-2013, 01:10 PM   #3
1968 26' Overlander
Sewell , New Jersey
Old 04-11-2013, 01:12 PM   #4
Central , Mississippi
Yup, ya gotta open the hole. If your Dexters are like the ones I installed in the 'Epiphany gets new axles' thread, you need to open the back and top side. I also slotted the rear bolt holes in the axle so they would line up. Most folks slot the trailer but to me I'd rather modify the axle than the trailer.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-11-2013, 01:27 PM   #5
1968 26' Overlander
Sewell , New Jersey
Well consider me intimidated. What do you use to open it up? A grinder? What do you use to slot the bolt holes?
Old 04-11-2013, 01:28 PM   #6
1968 26' Overlander
Sewell , New Jersey
Who lives in south jersey and wants to help?
Old 04-11-2013, 01:53 PM   #7
It's not too bad. Here is the photos that I took/method I used...
http://www.airforums.com/forums/f437...tml#post558525
Old 03-12-2014, 08:09 AM   #8
1981 31' Excella II
New Market , Alabama
I would use an angle grinder with a grinding wheel on it. How much bigger does the hole need to be? If it needs to be alot bigger use a thinner cutoff wheel to make a slot then cut and grind the tab off. A saws all might work for the rough cut then a grinder to smooth the edges. A cutting torch would work but kinda messy.
I would POR 15 that frame before installing the axles.
Perry
Old 03-12-2014, 05:40 PM   #9
reinergirl's Avatar
Hollis , New Hampshire
This thread was almost a year ago, I'm sure the OP has finished. Or at least mostly sure
reinergirl is offline   Reply With Quote
