Old 05-28-2014, 12:46 PM   #1
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
New Axles with 3" lift
Hat tip to Colin Hyde for sourcing my new Axles.
They fit perfectly (even with my 3" lift) and work great.
A big improvement no doubt, and no more dragging donkey at every gas station!
Name:	ImageUploadedByAirstream Forums1401302713.048784.jpg
Name:	ImageUploadedByAirstream Forums1401302743.862321.jpg
The hitch height is going to be about 2" higher.
Old 05-28-2014, 01:32 PM   #2
1973 29' Ambassador
Seattle , Washington
what did you use to raise them? ARe these the stock 22 degree axles with some additional blocking to create a 3" lift?
I had my old axles replaced and the guy who did it replaced them with zero degree axles, so I need a lift kit or something to create more clearance
dcheshire is online now   Reply With Quote
Old 05-28-2014, 06:59 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I used the stock degree axles.
In short we welded a 3" X 1/4" angle to the bottom lip of the old axle mounts (I.e. The bottom of the frame ) and then used a square to mark the slots for the axle.
There is a bolt on kit available to raise two inches for a couple hundred bucks.
I went the way I went for two reasons, one it was cheaper, I already had thirteen feet of angle, and two because I was able to remove a pretty good bit of frame sag by jacking the trailer from the rear and welding in the angle.
Old 05-28-2014, 07:09 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Name:	ImageUploadedByAirstream Forums1401325732.471590.jpg
Here is a before picture.
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
