Old 02-14-2003, 09:09 AM   #15
Axle alignment
All new axles are aligned, prior to shipment.
However, it is wise to check the axle mounting plates, to insure that they are mounted "exactly" correct.
Measuring from the center of the jack post to a reference on each of the axle mounting plates, will answer that question.
On a 31 foot trailer, if there is a difference of 1/8 inch between the axle mounting plates, it will cause the trailer to tow dog leg, about 2 1/2 inches.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 02-14-2003, 09:18 AM   #16
Jack Stands
Using cinder blocks in place of a jack stand, is asking on bended knees, to be severly injured, or KILLED.
If someone cannot afford to buy jack stands, and wish to do their own repairs, which required them, then they shouldn't own an Airstream to start with.
Brutal and blunt, YES.
DON'T EVER USE CINDER BLOCKS TO SUPPORT THE WEIGHT OF A TRAILER, OR MOTORHOME.
Your family will love you, if you don't.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 02-14-2003, 04:20 PM   #17
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Exclamation parady
my suggestion to pick to place his trailer on cinder blocks was a joke!
i was trying to be funny!
i own jack stands and use them all the time.
andy is correct! do it right or don't do it at all!
i hope no one was misled by my post.
john
Old 02-14-2003, 04:39 PM   #18
John,
So should I return my cinder blocks to Home Depot?
John
John is offline   Reply With Quote
Old 02-14-2003, 04:43 PM   #19
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
run john run!
john
go as fast as you can!
john
Old 02-14-2003, 04:57 PM   #20
New Borockton , Alabama
Images: 21
John, don't take them back! Grab that 2X8 and reconstruct that entertainment center like they were designed for in the first place, silly. Talk about "do it right or don't do it at all." Shoot, I saw sombody actually building walls out of them once, if you can believe it!
Randy
Old 02-14-2003, 06:31 PM   #21
I have jack stands and a 12 ton bottle jack to move it around with, the concrete blocks go in the root celler for walls, I ordered a complete set of axels from Andy today, probably be about here in three weeks, so after the snow clears out I will start taking the old axels off and get ready for the new ones, we are supposed to get 8" before the storm moves on. I got a Honda snowthrower, 28 " track drive, last year and not much snow, sure beets using the shovel.
Gene Wissink is offline   Reply With Quote
Old 02-14-2003, 07:10 PM   #22
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
randy and every one
all kidding aside, other than using cinderblocks for an entertainment center or a root cellar.
I WOULD NEVER CRAWL UNDER ANYTHING THAT WEIGHED MORE THAN ME THAT WAS SUPPORTED BY THEM!
even with proper jack stands i would be very cautious about getting under any vehicle if i wasn't 100% sure of the stability.
remember this is about camping with cool trailers. not getting hurt or killed by following someones advice!
if you're not sure, leave the job to pro's
safety first!
john
Old 02-14-2003, 07:40 PM   #23
Images: 21
Your right John, and TOTALLY right. I thought we were past that. Sorry.
Old 02-14-2003, 08:24 PM   #24
Thumbs up Humor
John HD,
I know this is a serious subject, but I'm sure Pick knew you were joking!!! Pick has a great sense of humor!!
I enjoy your off beat humor and I hope it doesn't stop you from sharing more in the future!!!
My girlfriend had a question about Thetford Drain Valve Lubricant, but I better not ask it, as I won't want anyone to injure themselves !!!
John
Old 02-14-2003, 08:35 PM   #25
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Thetford drain valve lubricant? Just keep your foot on the pedal, while your.....or someone's going to be screaming! Mine won't hold water, how hard is it to change out the seals? or will lubricant solve the problem?
/threadjack
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-14-2003, 08:39 PM   #26
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i heard..
pick/john
i heard it helps by swelling things up.
john
Old 02-14-2003, 08:47 PM   #27
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Pick,
Seal replacement is easy. Getting to the valve is the bear of the job. It took me 5 hrs to do the job, 1 hr round trip to the store 30 min to install the seals, and 2.5 hrs to pull the underbelly corner wrap to get to it and then reinstall the underwrap.
If you have an RV place near you they usually have the thetford seal kits on the shelf. The thing you need to know is what type of blade you have. In my 76 I have a plastic blade, you may have a metal one. The seal kits are different. Once you get to the valve it is just a matter of removing the screws and separating the 2 halves of the assembly. The seals can be pulled and new installed without cutting pipe if you have some flex/play on the outlet side. The tank side is usually well mounted.
Be sure to fully insert the new seal in the groove fully before reassembly. If you want to be sure to have the part in hand before disassembly of the valve you just need to get to it and read the part number off it.
Good Luck. PS wear gloves
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 02-15-2003, 07:01 AM   #28
I was on the fire department for 29 years and have been working with my brothers wrecker and crane business on many wrecks. I have been in places that would make a normal person think twice. I know if you do things right in the way you put in the cribbing and jacks or concrete blocks with the holes up it will hold things up. I even put down the outrigers to make things steady with cribbing under them if they would not touch the ground.
Attaching a single picture to your post PeterH-Airstreamer Forum Admin, News and Member Account Info 62 12-04-2004 10:44 PM
Torsion axles Silvertwinkie Axles 4 01-29-2004 08:18 AM
Are our axles undersized ? Mike B Axles 5 09-19-2003 06:21 AM
New Axles for '76 Argosy 26 76Argosy Axles 2 07-07-2003 08:31 PM
Adding a picture to a post wallybyam Our Community 5 03-03-2003 07:29 PM
