Old 11-24-2009, 07:07 PM   #15
Central , Mississippi
Originally Posted by mutcth View Post
...I'm wondering if Dexter dealers don't stock them because they aren't exactly treated as wear items - or if Dexter dealers don't stock them because they're unpopular...
Tom
My local dealer stocks the complete hub with bearings, the option is hugely popular with the big dollar horse trailer crowd. They report never seeing a bearing issue but has had a few brake drums outta round. I have heard of a fulltimer needing an assembly for that reason and getting it overnight from Dexter.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-24-2009, 08:23 PM   #16
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Safety Lube spindles
The Axis version of axle that I sell comes with their version of EZ lube. They call it "Safety lube" & I believe it's a great idea. It was developed for boat trailers that get submerged on a regular basis. This system allows the owners to purge the water from the bearings really easily. As Airstreamers tend to use their trailers more than the "white box" crowd, it allows you to replace the grease & or keep tabs on the bearing condition without removing the wheels. This system displaces the old grease & pushes it out around the grease fitting on the end of the spindle. This system doesn't eliminate the need to disassemble & flush the bearings out occaisionally.
Colin
Colin H is offline   Reply With Quote
Old 11-24-2009, 09:09 PM   #17
1963 19' Globetrotter
Moline , Illinois
I had that type of lube system on my boat trailer and it failed -on a boat ramp in the Minnesota boundry water area ,28 miles from the nearest town. You can only imagine the fun I had getting things back in working order. Needless to say both sides of the trailer now have the basic bearing system on them. The hour and a half repack job is a minor inconvenience.
63air is offline   Reply With Quote
Old 11-24-2009, 09:10 PM   #18
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
63air,
What part failed, the bearings, the spindles or ?
Bill
Just my personal opinion
Old 11-25-2009, 05:21 AM   #19
Baltimore , Maryland
Originally Posted by Inland RV Center, In View Post
We do not recommend the Nev-R-lube bearings.
We like to stay with the tried and true systems, namely keeping it simple.
Now is that due to a personal issue with the product or that you do not sell them? I suspect the latter.
If we were really into keeping it simple we all would still be using the leaf springs.
Anything made by man can and will fail eventually. The question is weather the road to failure is smooth or not.
Tom, unfortunately you have asked a question that will result in very strong opinions that in the end will lead you to severe frustration. Good luck.
Old 11-25-2009, 07:20 AM   #20
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That same vendor sells disc brakes, which are anything but simple, so you may be correct.
Old 11-25-2009, 08:30 AM   #21
The nev-r-lubes are available to us from Henschen.
Our choice, is to not sell them, since it absolutely destroys the owners attention to the brakes, and lack of in field replacement parts.
It seems like the human nature spells out, that if you can ignore the bearing issue for 100,000 miles, why do I need to pay any attention to the brakes. Electric brakes, even according to Dexter, should be adjusted every 3000 miles.
Don't bet on that happening when someone has the nev-r- lubes.
One of the most negleted area's of PM are the brakes on a travel trailer. Having worked on them for over 43 years, proves that point over and over again.
Many owners , when replacing axles, shift to disc brakes. Disc brakes are much more efficient than electric brakes, and do not require the every 3000 mile adjustments.
The recent failures with disc brakes, was with the actuator, in particular, the one made by "Actibrake", and not the brakes themselves.
Anything new, has it's learning curve, be it electric brakes or disc brakes. The issues regarding those are now long gone.
But, the proper PM of electric brakes is ignored by almost every travel trailer owner, either by skipping the adjustment issue and/or the routine visual inspection, once a year or every 10,000 miles, which ever comes first.
The new issue regarding electric brakes, might be the self adjusters. So far, the problem slate, is clean, and all reports have been 100 percent positive.
Old 11-25-2009, 08:41 AM   #22
Disc brakes.
The RV industries interest in disc brakes, is a good thing.
Disc brakes, on a travel trailer are just as simple as they are on a car.
However, the big difference, is the need for an "actuator" for the trailer disc brakes.
Other than for the recent failures of Actibrake actuators, there has not been any significant problems associated with the disc brakes.
The vacuum over hydraulic system Airstream used, was a pioneer all by itself. No other manufacturer tried them. However, once again, the problems with the original Airstream disc brakes, was lack of proper PM with the discs, which was minor, but much more so with the huge actuator. On the other hand, there are still many of the original Airstream disc brake systems still in use today.
Disc brakes, for travel trailers, is here to stay.
Old 11-25-2009, 08:55 AM   #23
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Just for info: My 2010 28 ft. Flying cloud came with neverlube bearings and self adjusting drum brakes.
jkcru is offline   Reply With Quote
Old 11-25-2009, 10:08 AM   #24
Airstream production, recently changed to self adjusting brakes, on all trailers.
So far, so good.
Old 11-25-2009, 01:58 PM   #25
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
It's a bit tangential (and likely beyond my budget), but adding discs requires finding a place for the actuator and running brake lines under the trailer, right? Are those lines exposed/running along the belly pan? That would seem to present risks - and a lot more plumbing work than I want for a $8000 2500 lb trailer...
It would seem to me that if AS is using the newer-type bearings with self-adjusting brakes on what sounds like a Dexter axle, I should be able to spec a Dexter axle with those goodies.
Likewise, if disc brakes had issues when they were new, and they were worked out, it would seem the same process would apply for Nev-R-Lube bearings. I don't plan on driving them into standing water like a boat trailer...
Tom
mutcth is offline   Reply With Quote
Old 11-25-2009, 02:12 PM   #26
Moline , Illinois
The bearings failed due to a lack of lubrication even though they were greased after every use. Everything was fried including the brakes and drum. Luckily the spindle was not ruined or it would have cost me a new axle. Some of these systems sound good but when you force that grease into the inner bearing you are blowing out the seal. The problems compound with a boat trailer, because you are usually going into the water with hot bearings. I'm with Andy ,I want to inspect everything.
As far as sealed automotive bearings go, I had one fail at 75,000 miles. Never had that happen with stuff I repacked.
Old 11-25-2009, 02:15 PM   #27
_
hi tom
yep disc installation means running lines and locating the actuator.
there are several good threads that reveal these diy steps, IF you want the links just ask...
it might be MORE $ and performance than you want or need for the gosy...
and it may depend on WHAT u tow with and how fast u wanna stop.
__________
i met a guy towing a bambi with a porsche cayenne.
the cayenne has massive brakes and stopping power, the bambi did not.
so his trailer got sideways during a panic stop on the interstate...
this was NO fuN and a bit scary.
and preceded his trip to j/c to have the disc upgrade for the bambi...
so matching the 2 vehicles' braking ability seems to be a useful notion.
cheers
2air'
Old 11-25-2009, 07:39 PM   #28
Tom
We suggest that the actuator be mounted in an access compartment.
That minimizes the steel tubing brake line exposure.
Also, it keeps the actuator out of the weather. Not that it matters, but we think that's a good idea.
You may have a neighbor that wants disc brakes, and if the actuator can be seen, well, how long might it stay there?
How do I get this off? (re: repacking bearings) Zstream Wheels, Hubs & Bearings 7 05-04-2008 08:58 AM
New Bearings Byron71 Axles 5 03-29-2006 01:32 PM
Wheel Bearings 85MH325 Axles 5 04-05-2004 06:41 AM
bearings Coloradobus Axles 4 11-01-2003 08:56 AM
bearings Dwight Axles 0 01-24-2003 09:58 AM
