Old 06-25-2010, 06:54 AM   #1
1987 29' Sovereign
viareggio , italy
new axles for Sovereign 29'
helloo everybody,
i'm trying to understand the max load per axle i should consider to change axles on my 29 sovereign.
The empty weight is 6000 lbs and full is 6800.
I found (i'm in Italy) a tandem axle with a max load of 7700 lbs. is this enough strong?
Please help me!!!!
Ciao
interno6 is offline   Reply With Quote
Old 06-25-2010, 07:14 AM   #2
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
My guess it that you will have 3200 lb axles. Each axle will be rated at 3200 lbs. Which is what I have on my 29' Excella (1989). It has the same 6800 GVW. You may want to contact Inland RV and they can give you a confirmation.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-25-2010, 07:44 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Why do you think you need new axles?
Old 06-25-2010, 07:55 AM   #4
Originally Posted by interno6 View Post
helloo everybody,
Please help me!!!!
Ciao
Those axles are the originals.
To check them out, you can read the axle article that's in the Airstream Central section of this Forums.
I suspect it needs axles DKB_SATX Axles 22 04-26-2011 09:39 PM
