Old 08-24-2008, 06:59 PM   #21
Alumicult in Oregon
edgeman's Avatar
1968 28' Ambassador
Seaside , Oregon
Smile
Since there were no previous holes cut in the floor I am unsure how the previous owner contributed to the installation of the bolts up through the floor without a body off floor replacement. I am the second owner and purchased this unit from the neice of the first owner through an inheritance. It sat in a barn for ten years before I purchased it in 2005. As we all know sitting in a barn for a long period of time is not a good thing. I agree with Andy that there is no need for the vertical bolts as the axles are held in place by the cuts in the frame and the fact that they cannot not move in any direction. Never the less some where along the line (I beleive the factory installed them) bolts were installed vertically on the assembly line for a period of time and the nuts were not tacked in the channel. Again I had to cut holes in the floor in very difficult locations to be able to place a wrench on the nuts to remove the axles before i could in stall the new axles. Unfortunately I did not take any pictures of the locations but could take them after the fact if you needed them. for us it was a simple function of measuring the distances and you can come fairly close to the correct locations of the nuts. Good luck if you have to do the replacement.
edgeman is offline   Reply With Quote
Old 08-24-2008, 07:38 PM   #22
According to Airstream, they "never" installed any torsion axles with vertical bolts.
Old 08-24-2008, 07:48 PM   #23
Alumicult in Oregon
edgeman's Avatar
1968 28' Ambassador
Seaside , Oregon
No disagreement from me I am just telling you what I had to deal with when my axle replacement occured. I do wish this had not been the case because the replacement would only taken a day. Trust me, my back wanted no part of vertical bolts.
Old 08-29-2008, 08:50 PM   #24
1973 31' Excella 500
Morristown , Tennessee
I'm a big "Andy" fan. I bought a 73 Excello in Chatanooga, Tn and noticed that the arms were above parallel. I pulled it home to Florida and scraped the rear on minimal bumps ie going into a gas station. There was no question I was going to get new axles. The choice was simple - Andy had plug and play. Shipped to my local carrier, jacked up the trailer, blaster (penetrating oil) the bolts and remove with an air impact. Roll out of the way with a floor jack and roll the new one into place. Bolt on the new bolts loosely and repeat on the next axle. Lowered the trailer to raise the axles on the frame and tightened the bolts. Put on the shocks and connected the brake wires. Took about three hours work with my 10 year old sons help. The ride is great, the brakes work great and my milage increased by 4-6 mpg.
I recommend this for any DIY. Dont forget to return the old axels to the salvage yard. I got $123 for the metal. Andy also though in an Airstream key chain - one of the nicest surprises ever. Thanks for all of you help, Andy.
Joe
Alumin8 is offline   Reply With Quote
Old 08-30-2008, 07:26 PM   #25
mustang's Avatar
1999 27' Safari
Kent , Ohio
Tim and Mex you guys are going to get a nose bleed way up there.
mustang is offline   Reply With Quote
Old 08-30-2008, 09:41 PM   #26
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I replace the axles on the Overlander with a little help from my neighbor who has a asphalt drive.Did I mention Im 70 yrs old? With 4 peices of plank to drive up on/2 wheeldollys purchased from Harbor Freight and a floor jack and of course our impact wrenches. TOTAL TIME 2 1/2 hrs.With the new Henshens ordered thru Andy, I picked them up at the factory on my flat bed trailer.
A Piece-O-Cake I gained about 4 inches in higheth,enough so I had to lose the 4" BlueOX drop from the hitch.
We are very please with ANDY and the New Henshens.
Roger
Mikethefixit is offline   Reply With Quote
Old 09-01-2008, 08:47 AM   #27
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
I'm leaning towards the DIY axles... although they have to come off again when someone else does the frame and floor work. Now, I haven't pulled the hubs off my current axles, but I'm guessing the brakes are shot as well. The PO also put a wire to the rear axles. He said it was something about making sure the brakes were getting juice. I hope my wiring back to the brakes isn't junk.
hampstead38 is offline   Reply With Quote
Old 09-01-2008, 10:56 AM   #28
64TrotterAtl's Avatar
1964 19' Globetrotter
Decatur , Georgia
Correct. We supply the grade 8 hardware with all of our axles. Bolts, nuts, lockwashers and flat washers are all grade 8.
Clean up any rust etc, and then paint the area completely.
No template needed. Simply drill the holes, one forward of the axle tube and two rearward of the axle tube.
1968 and back trailer axles will have the shock brackets not installed. Have them welded as you need them placed. There is a huge difference in shock bracket placement between the 2 plants as well as different models, as well as different years, therefore they must be field installed to allow the necessry clearance.
Then, the shocks can be installed later.
Also, once the brackets are in place, they can be bent outward to allow more clearance, if necessary. They can also be left in the bent position, as it will not cause any harm.
The shock brackets can be welded in place, without causing any damage to the rubber rods, or voiding the warranty.
Ask questions first, then the rest falls into place.
Assuming, usually causes the problems.
Mechanics is not difficult, but some people insist on making it that way.
We go to school to learn.
Different schools are available, regardless of the subject, even as short as one sentence, during a persons entire lifetime.
Different schools sometimes offer different methods, for different things, and they rarely include opinions.
The individual, must weigh that knowledge and make it fit to their liking, or their personal needs, or pocket books.
But as in grammer or high schools, some students get A's, and some students get F's, or the many grades in between.
Owning an Airstream, and being a DIY owner, keeps the brain on track, as there is usually always something to learn.
Not being a DIY person, also has schools, where you learn to pick out the right dealer (regarding Airstream) who has the correct knowledge, a good shop staff, a decent shop and at reasonable prices. Most graduate quickly, a few fail the course.
Some people replace tools, because they wore them out.
A few replace tools, because they broke them, usually through misuse.
And when you get older, like a senior, you buy some tools, because you either lost them, or you don't remember where you left the darn things.
And so it is.
Andy[/quote]
Do you have any pictures of the process. for example, a 64 GT with an old axle, removal of the axle, the old shock bracket vs. the new one, and then close-up pics of where the hole should be drilled, etc....
Anyone who does, please help me. I will be ordering the axle from Inland RV and want to visualize what I am doing, Andrew
64TrotterAtl is offline   Reply With Quote
Old 09-01-2008, 10:57 AM   #29
Decatur , Georgia
Pictures please
New Axles LHall Axles 10 10-06-2007 09:43 PM
New Axles LHall Axles 4 08-09-2007 02:17 PM
Axles and such... Anon Axles 60 06-11-2005 02:26 PM
Do these axles look OK? 66Overlander Axles 11 10-22-2004 07:27 AM
Do I need Axles??? blucloud Axles 3 08-16-2004 07:23 PM
