09-19-2007, 12:23 PM
2020 30’ Globetrotter
2001 30' Excella
Phoenix
New Axles
I just wanted to take a minute to say... Hooray! My new axles arrived and I installed them over the weekend. I will post some pictures when I get the chance to download them from the camera. I have to say that the project was not nearly as difficult as I imagined it would be. The new axles from Inland RV went right up in the slots. The hole drilling was not that bad and everything bolted up nicely. I did however discover one issue that was a problem on the first axle. Since the arms were nearly at a negative angle, the bolts would not come out far enough to drop the axles. I had to cut them off and the axle came right out. On the rear axle, I discovered that if I jacked up the arm it moved just enough to get the bolts out and no cutting was needed. I am amazed at the height difference in the trailer. I must have gained at least 4" in height. The new axles have a space between the belly pan and the top of the cross piece. This was nice when re-routing the gas line for the water heater. I just tucked it up next to the belly pan and re-fastened it to the belly pan. Now the gas lines are up and out of the way of any road debris.
I only towed it about 15 miles since and what a difference in the ride. I feel much more confident about the safety and roadworthiness of my 45 yo. trailer.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
09-19-2007, 12:46 PM
1993 34' Excella
Estancia
, New Mexico
Gas lines and axles
Are you sure the axles won't in time pinch off the gas lines?
09-19-2007, 12:54 PM
2001 30' Excella
Phoenix
There is at least a 2" space there and the upper bracket on the axles is tight against the trailer frame. If the gas lines were routed in the center of the trailer, I may say yes, but as you know the axles have a bow in the main cross bar which leaves a nice space on the edges. The axle brackets would have to break in order to pinch off the gas line.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
09-19-2007, 07:44 PM
Retired.
, At Large
I looked at that with our 63, and there is space between the axle tube and the belly pan to route the line above the axles. Just make sure the line is secured tot he belly pan so road vibration doesn't eventually rub a hole in the copper line.
09-20-2007, 08:56 AM
2001 30' Excella
Phoenix
I agree with that advice and did just that. I used the factory aluminum clips and riveted the gasline up to the belly pan. It worked great.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
09-24-2007, 11:46 AM
2001 30' Excella
Phoenix
New Axle Photos
Moving dollies made it easy to maneuver the axles under the trailer.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
09-24-2007, 12:03 PM
2001 30' Excella
Phoenix
Axle photos
More photos
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
09-24-2007, 03:10 PM
2003 22' International CCD
Whittier
New Axles
Congratulations. Glad to hear it was less of a deal than expected. This is good input to the database on axle replacement and the pictures help a lot.
10-06-2007, 10:13 AM
1969 27' Overlander
Colorado Springs
great job, what angle?
Nice work! What type of angle did you order on the torsion arm to get that much clearance improvement?
Deano
10-06-2007, 10:53 AM
2001 30' Excella
Phoenix
Angle
Deano
Hello Deano,
When I ordered the Axles from Inland, Greg asked me if I wanted to upgrade to the 3000 # axles which I did, he informed me that they would have a 33 degree angle, if I remember correctly.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
10-06-2007, 08:43 PM
Corona
Hello Deano,
Make that starting angle 35 degrees.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Axles
nairnchyz |
Axles |
3 |
04-02-2007 02:13 PM |
New Axles
garthbf |
Axles |
4 |
08-07-2006 07:27 PM |
New axles?
mtnman |
All Argosy Trailers |
1 |
12-02-2005 07:23 PM |
Need New Axles
Navigator |
Axles |
138 |
12-19-2004 10:00 AM |
two vs three axles?
newmanjk |
Axles |
17 |
08-05-2004 04:03 PM |
