Old 04-06-2011, 08:28 PM   #1
1989 34' Limited
southern , ontario
New axle sheared in two. Advice needed.
I had 3 new axles installed in 2008 I have approximately 10,000 mile on them, on april 1 2011 the rear axle snapped in two at the point that fits inside the rubberized torque tube (the 1 1/4 square solid steal bar sheared there was only 2 pencil widths of steal holding the manufactured bar together 3/5 of the sheared face was coverd in rust).
I have been told by the original installer that its my problem and a new axle will be a $1000,
the original axles lasted 19 years, is there any claim by AIRSTREAM that their axles are unbrakable, or is there anyone at airstream that I can contact,
what recourse do I have???
any Input will be appreciated
letsgo is offline   Reply With Quote
Old 04-06-2011, 08:37 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I'd raise hell! Notify Airstream,and see what they say. I don't have much faith in that...but its a place to start. I guess its a Henchen axle??? With all the Company changes I have heard about I suspect you will get lots of telephone runaround. I'd also check in with Andy at Inland. He is such a big promoter of that axle replacement and has extensive history with both Airstream and Henchen. Go from there. Good luck!
Old 04-06-2011, 08:46 PM   #3
What brand axle do you have, and what is it's rating?
Old 04-06-2011, 10:24 PM   #4
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Do they use salt on the roads in Ontario? Who did the replacements.. and why were they replaced? Those 34's are heavy.. but it sounds like metal failure secondary to rust?
Got pics?
Marc
Old 04-07-2011, 07:35 AM   #5
dznf0g's Avatar
Oswego , Illinois
Got pics?
Marc
I think what th OP is saying is that the shear surface had some surface rust on it, indicating the partial shear had taken place over some time or some time ago. I didn't get the feeling that the OP felt tht corrosion was a contributing factor.
Old 04-07-2011, 08:24 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Sounds like the axle was defective from the start. I think your only recourse is to take pictures to show that the axle came with a partial failure and to politley ask the supplier and/or manufacturer of the axle to provide a replacement or money to cover th replacement. If you can get to the right person and show them that it was a manafacturing defect I think they might do it. I have not often been successful with a brute force negotiation. You can always write that RV magazine that does the action line column.
Or just do the $1000 replacement, ask the company to discount it a bit, and be happy if there was not collateral damage when it happened.
Old 04-07-2011, 08:52 AM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
I'm thinking Airstream had nothing to do with this. The reference to 'original installer' not standing behind this suggests this replacement axle wasn't installed by the JC Service Center. So letsgo's avenue to pursue this is with the axle manufacturer only? It will be good to hear which brand axle was used.
5 meter Langford Nahanni
Old 04-07-2011, 09:04 AM   #8
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I think your right
Old 04-07-2011, 10:10 AM   #9
1977 Argosy 24
Milltown , Wisconsin
Like Andy said, what is the weight rating of the axle and who made it? If it had too little of a weight rating and broke it's not the axles fault, it's the person who bought the wrong weight axle for a heavy trailer. If the weight rating was correct and it broke it's the axle manufacture's fault, if it was installed correctly.
ventport is offline   Reply With Quote
Old 04-07-2011, 10:29 AM   #10
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
The 34ft airstream Classic or excella is about 1000lbs heavier than most of the dual axle 30ft airstreams.
However because they have 3 axles and the load is evenly distributed .It shouldn't have as much load on them. I could be wrong, but I would be suspicious about the axle weight ratio like Andy seems to imply!!!
Sorry about your problem!!!!
william Haym is offline   Reply With Quote
Old 04-07-2011, 10:56 AM   #11
dznf0g's Avatar
Oswego , Illinois
Well, maybe. If someone put three 3500 pound axles on, while technically within GVWR of the trailer, there is ALOT of lateral scrubbing during maneuvering which may be excessive for a 3500# axle. Also, you are assuming that all 3 axles are loaded equally. May or may not be the case. I don't even know what the trailer came with, but I think I would want 5000# or even 6000# axles.
Old 04-07-2011, 11:02 AM   #12
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my first thought was that the axle was defective, but then I was thinking that maybe a sideways push from hitting a curb could break it too. Then it would also have a bent wheel or something to go along with this curb theory. Pictures and a more detailed explaination of how, when, and where this axle actually broke, might better explain why it broke and who should pay the bill.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-07-2011, 11:15 AM   #13
Salem , Oregon
Images: 18
Hi, if you go to the Dexter axle site, there is a statement that seems strange to me. Check it out and let us know what you think about this statement.
"CAUTION: Triple axle assemblies are not recommended for Torlfex axles."
2005 Safari 25-B
Old 04-07-2011, 11:39 AM   #14
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
YIKES!!!
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
axle
Video - Successful Axle Job on 1964 Safari JitneyBead Axles 10 05-21-2012 09:07 AM
First time buyer seeking advice Broccoli Buyer Guidelines 14 04-14-2011 11:24 PM
Looked at airstreams today.. Advice needed. mikeandnora Buyer Guidelines 45 02-09-2011 11:27 PM
