Old 07-10-2009, 10:11 AM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
New axle purchase timing
Andy of Inland RV pointed out that I most probably need new axles. Was wondering if you are doing other restore/renovations that you expect to take a year or longer, would it be best to do the axles last or immediately. I thought I read somewhere that the axles go bad if not being used.
SilverHoot is offline   Reply With Quote
Old 07-10-2009, 10:32 AM   #2
Tosion axles go bad if a substancial weight is applied to them over an extended period of time, ball park 2 to 3 years or longer, without being moved or exercised.
They can go for several years without going bad, if they are on a shelf, or if on a trailer and the bulk of the weight is removed.
In the case of a major trailer overhaul, jack stands or at least stabilizer jacks should be in place, to keep the frame in alignment, so that furniture and the like are properly located and fastened.
Once torsion axles have been placed in actual extensive load carrying situation, they should be on the road at least eve3ry 18 months, or more often if possible.
In the case of long term storage, the majority of weight should be removed from the axles. That can be done with the tires on a 2 x 6 and the trailer elevated and supported with jack stands, so that the weight on each tire is minimized.
Torsion axles do not go bad, when there is no weight impressed upon the rubber rods.
Old 07-10-2009, 10:43 AM   #3
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Silverhoot,
I have never replaced an axle and I do not know how long it takes a stationary trailer to ruin a set of axles. but I think budget would be a large consideration when to do it.
You could always do the axles early and leave the trailer jacked up, properly supported, and put the wheels on once your rennovation is complete. That way there will be no weight on the new axles and it will make it all the harder for thieves to make off with your pride and joy.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 07-10-2009, 10:43 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
If the rig isn't going to be used on the road until your restoration is pretty much finished, then it probably doesn't matter when you do it. Just do it before you start journeying about!
Lynn
WBCCI 21043
Old 07-10-2009, 10:45 AM   #5
SilverHoot's Avatar
1967 24' Tradewind
Deitz645,
Great points and had not thought of merely jacking it up until completion. Thanks!
Old 07-10-2009, 11:16 AM   #6
DEITZ645's Avatar
SilverHoot,
As an aside...you are from Redding, CA and I live outside of Reading, PA. (as in the Reading Railroad on the Monopoly board) Pronounced the same way, but different spellings.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Full timing, where possible? dmac Winter Living 13 01-07-2010 02:22 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
full-timing njoysrvin Full-Timing 5 06-13-2006 09:20 PM
Full Timing abruce Full-Timing 10 01-29-2005 11:29 PM
I'm off full-timing! zduke4x Full-Timing 10 03-08-2004 10:06 AM
