Old 06-12-2009, 08:35 AM   #1
1974 Argosy 24
Winston Salem , North Carolina
new axle on argosy
well, here it is, a few pictures from my adventures on installing new axles on my 74 Argosy
Thanks to Andy from Inland RV the ordered axles did fit like a glove.
since i did not have a floor jack to raise the axles in place i decided to take two of the stabilizers off and turn them around, fix them on two dollies ( one for each side) and lower the old one and raise the new in. No problems
I will take the new set of wheels for a camping trip next week, just about 150 miles from home.
Is there anything i need to watch out for, new breaks etc??????
Name:	axle change (8).jpg
ID:	82131   Click image for larger version
Name:	axle change (3).jpg
Name:	axle change (9).jpg
ID:	82133   Click image for larger version
Name:	axle change.jpg
michael13 is offline   Reply With Quote
Old 06-12-2009, 09:20 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Yes.
Stop after 10 miles, and make sure the wheels are still attached, and none of the hubs is hotter than the others. Do this several times for the first trip out, say at 10, 25, 50 100 and when you get to the campground.
On the way back, stop at 10 and 50 miles.
Old 06-12-2009, 10:09 AM   #3
Your photo shows the shock upside down.
Water can collect in that cavity and cause some rust where you don't want it.
Old 06-12-2009, 11:22 AM   #4
1974 Argosy 24
That's what you get for following/ installing "how it was before"
so, axles back out and switch the shock
Thanks Andy for pointing this out
Old 06-12-2009, 12:39 PM   #5
Roy B's Avatar
1998 19' "B" Van Airstream 190
Athens , Georgia
Images: 47
Oh he's good isn't he, I looked at the picture and didn't see it till he pointed it out.
Roy B is offline   Reply With Quote
Old 06-12-2009, 02:54 PM   #6
You shouldn't have to drop the axles to change the shocks.
If the shock bracket on the torsion arm has a tight fit, just bend it with a croe bar so that the shock can easily slip off.
You can leave that bend in that bracket, if you wish, as it will not cause any problems.
Axle GVWR for my '78 Argosy Minuet COArgosy78 Axles 18 05-25-2009 08:12 PM
1974 Argosy by Airstream 24' Tandem Axle Southern Belle eBay Watch Airstreams on eBay 0 05-21-2009 09:50 PM
'78 Argosy Motor home axle smitty66@mac Axles 0 01-28-2009 08:39 AM
'75 Argosy 22' Axle Photo and Question uniquemicro Axles 3 10-18-2008 02:44 PM
My new trailer - Argosy 35' triple axle, 5th wheel Luka All Argosy Trailers 9 10-05-2003 12:08 AM
