Old 05-17-2012, 01:41 PM   #1
bcaffee29's Avatar
1962 24' Tradewind
Adger , Alabama
New axle for a '62 Tradewind
Have a 62 Tradewind single axle that needs to be replaced. What size do I need? Also which name brand do you guys suggest.
bcaffee29 is offline   Reply With Quote
Old 05-17-2012, 11:01 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you crawl under the trailer there may be a tag on the axle with the weight rating. My '74 has the weight rating on the VIN number tag.
Old 05-21-2012, 10:25 PM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Your trailer originally came with a 4000 lb axle. This would be a nominal 5000 lb axle de-rated to 4000 lbs. Axles are de-rated during the fabrication process by shortening the rubber rods before assembly. Depending on the direction of your restoration/refurbishment, you may want to up-rate your new axle to suit your current or expected final weight.
Colin
Colin H is offline   Reply With Quote
