Old 06-23-2013, 08:37 PM   #15
Phoenix , Arizona
What was the outcome of this situation?
M2HB is offline   Reply With Quote
Old 06-24-2013, 04:08 AM   #16
Baltimore , Maryland
I would love to know the same. I am going over to the Eastern Shore today and would have swung by. One post might be the reason for no response....
Old 06-24-2013, 08:10 AM   #17
In the very early 70's, many Airstream's had a different tire clearance from one side to the other.
It had to do with how the chassis was attached to the floor.
The chassis was tilted to 90 degrees, and was only supported at the coupler and bumper.
That caused the chassis to sag, of course, in the middle.
Then the floor, which was assembled as one piece, was attached.
I caught that error when I was visiting a dealer in Ohio, while I was with Caravanner Insurance, training that dealership.
Shortly afterwards, that boo bo method was corrected.
Old 06-24-2013, 02:54 PM   #18
1973 29' Ambassador
betterton , Maryland
Checking In
I went back to the trailer business and told them that I was not going to accept different rims to correct the problem. I also told them that I wanted the axles sent back to Dexter to change the height setting on the axle so the AS was not setting low on the tires. The top edge of the outside wheel well was about level with the top of the rim. I felt if the AS was sitting higher that much less of the tire would be inside the wheel well. I did measure the distant between the front axle and the real axle and the measurement was the same. When the axles are replaced back on the AS I will re-check that measurement and that of the front axle. The tire size that is on the AS is ST225/75R15. Many thanks
ducks is offline   Reply With Quote
Old 06-24-2013, 03:08 PM   #19
If a dealer, especially a non Airstream dealer was asked to order axles for an Airstream, how would they know what the original specs were, let alone increase them to raise the trailer higher than original.
Some Airstream parts, should be obtained from an Airstream dealer, who "hopefully" knows exactly what to order.
Maybe that's why only one Airstream dealer specializes in axles, amoung other things.
Not know where to start, doesn't help very much to get to the end.
There is more to ordering a torsion axle for an Airstream, other than measurements.
Old 06-24-2013, 03:31 PM   #20
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Those axles were doubly wrong, then. Sitting that low when they're brand new, someday when they wear out you'd probably be scraping the top of the wheel well with your tires and changing tires would be very difficult. On brand new axles you should see a few inches of tire above the upper edge of the rim and below the line of the wheel well. Maybe they were the wrong weight capacity, or the wrong start angle?
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
New axle for 1969 Caravel scottwtalley Axles 10 12-17-2011 08:01 AM
