I finished putting in my new Dexters and hooking up the brakes. I can already see the trailer now tows straight and looking at the wheels they seem to be parallel and straight. As a general rule should I have the alignment checked, or an alighnment done?
PS. I did an earlier post about a brake wiring problem. Turns out the brake ground wire was in the wrong position in the 7 way. And for some reason the brake ground wire is red. The 2 red wires were connected to the left tailight psoition. As soon as I figured this out and connected the red ground wire to the ground position in the 7 way the brakes work perfectly
This also means that I was unaware I was previously towing the coach sans brakes
