Old 03-03-2008, 11:22 AM   #1
1977 Argosy Minuet 6.7 Metre
Trinity , Alabama
New Axle
I decided to order axle and shocks for my 77 20 ft. Minuet from Inland RV.
Installed axle yesterday and everything bolted up no problem but, shock bracket is welded at side of arm where old one is in center and this causes shock mounts to be a little out of line.
My axle weighs 3000 lbs on Cat scales and even though axle was upgraded to 3500 lbs and starting angle is 35 degrees down, arm only has slight down angle under load. I believe 22.5 degree down starting angle and 3000 lb. rating axle would have slight up angle or at best be parallel right out of box.
Just by standing in rear of trailer and bouncing it you can tell big difference. My old axle was indeed past its prime.
norsim is offline   Reply With Quote
Old 03-03-2008, 12:46 PM   #2
Sheridan's Avatar
1965 17' Caravel
Mountainous , Utah
Nosim,
How much does a 20' Minuet weigh? My Caravel weighs 2250 lbs. and the stock angle was 22.5 degrees down. The original axle thats on it now is resting a about parallel after 43 years of service. I expect the new axle to be down a few inches (and conversely, the trailer up a few inches).
Dan
Sheridan is offline   Reply With Quote
Old 03-03-2008, 03:42 PM   #3
Trinity , Alabama
Originally Posted by Sheridan
Nosim,
Dan
From owners manual:
GVWR 3500 lbs.
GAWR 3000 lbs.
Dry weight as equiped 2668 lbs.
Dry tonque weight as equiped 436 lbs.
Rechecked my scale ticket axle weight was actually 2900 lbs. even.
Did not weigh tonque seperatly.
My old axle had probaly 8-10 degrees up angle and I gained about 3-4 inch height with new axle. Does not sound like much difference but trailer looks to be a lot higher.
Henschen web site shows parallel arm at rated load for new axle with 22.5 degree starting down angle.
Old 03-03-2008, 03:58 PM   #4
brownsmtnlab's Avatar
1970 31' Sovereign
Greeneville , Tennessee
Images: 8
For an extra $50, my dexter dealer shipped one of my two axles to their factory (a one way ticket) and they copied it there (times two). No fuss, and no measuring mistakes. I was very happy with the end result, and didn't have to measure a thing...By the way, not to cause trouble, but I sided with their engineers (and a few well traveled forum members) and left off the shocks...We have done 2500 miles now with the same used propane lamp mantle still intact, and have never had a cabinet door pop open.
If you don't know where you're going, any road will take you there
brownsmtnlab is offline   Reply With Quote
Old 03-03-2008, 04:18 PM   #5
Trinity , Alabama
That is good to know a little late for me though. For what it is worth my 30+ year old shocks felt no different than new shocks.
Old 03-19-2008, 12:29 PM   #6
vhord's Avatar
Images: 96
Did the new axles bolt right up or did you have to elongate the holes and shave the c-channel as others have done?
I will be replacing mine this year and this may be a good option.
vhord is offline   Reply With Quote
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Old axle vs New axle feedback . . . GetOutDoors Axles 21 08-09-2007 01:59 PM
Does this look like I will need a new Axle? kneal Axles 21 01-22-2007 04:51 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
