Old 11-19-2013, 12:26 PM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
New axle
Hello,
Im planning on ordering a new hub and axle assembly from colin hyde for my 1959 trade-wind and having it installed locally.
Can anyone in the washington dc or Fredericksburg area recommend a good garage or shop to have this work done on a vintage airstream?
Steve
Stephen.h.irving@gmail.com
steveirving is offline   Reply With Quote
Old 11-19-2013, 01:37 PM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Hey Steve. There is a member in the Baltimore area that does classic AS work. Seek and ye shall find. From what I read here it is not a bad do it yourself job either if you have space to work and time.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-19-2013, 02:48 PM   #3
1959 24' Tradewind
Quantico , Virginia
Images: 11
Im in a grad program now and renting. No space or time do you have a contact number?
Old 11-19-2013, 03:34 PM   #4
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Okay 62overlander time for you to appear! Doing it yourself is not hard and you can do it in a couple of hours! Good choice on airstream love that year!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 11-19-2013, 05:24 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Replacing a spring-type axle on a 1959 model with a torsion axle is more than a couple hours' work. The old axle and springs will have to be removed, a mount for the new axle fabbed and welded in place, then the new axle can be installed.
Old 11-19-2013, 06:23 PM   #6
Ottawa , ON
Steve,
Why do you want to do away with the spring suspension?
Old 11-19-2013, 07:13 PM   #7
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Originally Posted by steveirving View Post
Hello,
Steve
Hi Steve,
Call Frank at Frank's Trailer Works.
Contact us
Lance
Top is offline   Reply With Quote
Old 11-19-2013, 07:26 PM   #8
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
Where did he mention anything about a torsion axle? Spring axle swap is simple if using factory setup. Couple hours max.
panheaddale is offline   Reply With Quote
Old 11-19-2013, 07:32 PM   #9
Well Preserved
1993 21' Sovereign
HE didn't. Colin DID, when we swapped texts about it.
Old 11-19-2013, 07:58 PM   #10
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Not sure Colin sells leaf axles.
back to the question - "Why do you want to do away with the spring suspension? "
One can assume the "springs" are no longer doing the job. If that is the reason, I would suggest a new set of leaf springs. As suggested above going to a trailer shop (and yes shop around) to get a new set of leaves installed.
>>>>>>>>>>>>>>>>>>Action
