Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 03-18-2006, 10:24 AM   #1
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
New Axis axle
This thread will take a few weeks to mature, so stay tuned.
The axle arrived yesterday (in discussion with freight company, I found you can reduce your freight cost significantly if you pick it up at the terminal--residential delivery added $55 in my case).
At first look, the axle was manufactured very close to my specs. I'll only know how precise the mounting bolt holes are after I trial fit the axle. My first impression is very good. One concern is that the weld bead on the axle bracket may interfere with a good, close fit to the flange to the frame. So I got under the trailer and took a look--Yes! AS put a weld bead relief in my frame member! Too cool. I do have a remaining concern that the Axis bead is just a little too big in spots and may require a little grinding, see red arrow.
Yesterday, I took a look at Fred Coldwell's axle on his '64 Globetrotter and it does not have the weld bead relief. I'll get some photos today to make sure and will post them later this weekend. In any event, it is something to watch for, since Fred's axle fits perfectly in the frame cutout and the bracket on the axle is tight to the frame--no room for a weld bead as far as I could see.
One [sort of] comical item is that the shock bracket is on backwards. No one seems to think the shocks are really needed, so no biggee, but I will get a welder to reverse them eventually. I took a look at the drawings which I sent to Axis and I can see how they could have easily been read the other way. urk, dope slap to me.
Name:	IMG_4805 frame bead relief-s.jpg
ID:	19516   Click image for larger version
Name:	IMG_4810 weld bead-s.jpg
Name:	IMG_4802 shock arm-s.jpg
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com www.pygmykayaker.com
Zeppelinium is online now   Reply With Quote
Old 03-18-2006, 11:15 AM   #2
Stefrobrts's Avatar
Profile:  1968 17' Caravel
. , Washington
This will be an interesting project to follow along on. I may have missed the discussion in another thread, but which trailer is it for?
Stephanie
Old 03-18-2006, 11:47 AM   #3
AirstreamGypsy's Avatar
Profile:  1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
This is for his 18' Caravel.
Sorry can't remember where the previous post was.
AirstreamGypsy
___________
AIR # 11128 WBCCI # 1818 - VAC
Charter Member FCU
CP
(Courtesy Parking)Wi-Fi
http://www.sdgraphics.net/myearthship/
AirstreamGypsy is offline   Reply With Quote
Old 03-18-2006, 05:00 PM   #4
1977 23' Safari
1975 31' Sovereign
Sorry, all. This is for a 1971 18' Caravel. I think this is going to work for all early 70s trailers--I'll let you know as I do my 1972 Overlander and 1975 Excella.
OK, I didn't need to go over to Fred's after all. Stopped by Cherokee RV Salvage on the way to the Denver Unit Luncheon and got these photos of a 60s axle. You can see that the axle brackets are just flat pieces of steel, compared to the curled-over shape on the 70s. You can also see that the trailer frame member is flat--no curled edges on the axle cutout, so no room for a weld bead on that side of the axle bracket. Just one difference to look for.
I think that the 60s trailers can accept an axle with the curled-over (inverted "U" shaped) bracket, but you'd have to specify that the weld bead that goes around the top half of the axle tube be on the inner side (away from the wheel) of the bracket.
Name:	IMG_4817 two axles-s.jpg
ID:	19524   Click image for larger version
Name:	IMG_4815 tight flange-s.jpg
Old 03-19-2006, 06:49 AM   #5
Streamin 65's Avatar
Profile:  1965 26' Overlander
Marysville , Ohio
Images: 14
Heck Led, I could have posted the 60's pix for you if only I read this a little sooner! I pulled one of the axles from under my '65 yesterday. It was a fairly easy job other than I had to cut the rear bolts off as the arm was high enough up to block clearance to remove them. The angle of the arm was still downward somewhat, but it seems the axles have taken a set. When I jacked up the trailer, the wheels stayed in the same position (they didn't drop at all when I lifted the trailer ). I haven't decided where to get the new axles yet, but am anxiously waiting your update. Hope all goes well! Thanks, dave
Streamin 65 is offline   Reply With Quote
Old 03-19-2006, 07:07 AM   #6
Marysville , Ohio
Images: 14
One thing I forgot to mention.. I emailed Chad at Axis last November to get a ballpark estimate for installation of two new axles. He gave a good price on the axles at $300-$350 each, but also stated " We have replaced some of these axles in the past but have made the decision to no longer do service work at our facility. They are fairly simple to replace if you do decide to do it yourself." --dave
Old 03-19-2006, 11:19 AM   #7
1977 23' Safari
1975 31' Sovereign
Dexter axles are about the same price and come without having to pay the shipping. They have outlets all over the country and will do the installation, for a price.
I'm going to stick with Axis. I did some accurate measurements yesterday (as it started snowing)--axle looks perfect to my specs. I may have to grind the weld bead a little, but I can accept that. Unfortunately, I'm outta here for two weeks and the weather is bad today, so I won't have the installation photos until I get back.
Old 03-31-2006, 11:46 PM   #8
1977 23' Safari
1975 31' Sovereign
slow progress
Hello, all. Finally found the time to drop the axle. Here's a few steps and photos:
1. Make sure you get the jack under the axle before you try to remove the bolts. Don't be cocksure (I have lots of experience, here)--have your penetrating oil handy or you'll probably not get the nuts off. Mine weren't so bad after 30 years, but I still needed my biggest 1/2" breaker bar and about 30" of 2x4 (not a lever, a hammer) to get the first nut movement.
Name:	IMG_4867 old axle installed-s.jpg
ID:	20024Click image for larger version
Name:	IMG_4870 axle jack-s.jpg
2. Dropped the axle and took some comparative photos--yes, the shock bracket is backwards on the new axle, but I could have done a better job on the drawing. As it turns out, I'm going to cut off the old brackets and re-use them.
Name:	IMG_4877 old shock bracket-s.jpg
ID:	20026Click image for larger version
Name:	IMG_4879 new shock bracket-s.jpg
3. Why? Because even though Monrow inculdes a new shock mounting stud, it's [IMHO] too short. One photo shows the included hardware, but you can see it's just not what the doctor ordered. Not to mention that in addition to the stud portion being too short, the threaded portion is too long--it would definitely hit the jacking flange. One other thing to note--the hole in the Axis bracket is 1/2", but the non-threaded portion of the stud is 5/8". Not a big deal, but something to make sure you put in your order if you have your own shock mounting studs. (btw, the white stripe behind the bracket on the new axle is a piece of shim from another project, not a Photoshop artifact.)
Name:	IMG_4874 new shock-s.jpg
ID:	20028Click image for larger version
Name:	IMG_4876 new bolt-s.jpg
Name:	IMG_4880 shock bolts-s.jpg
to be continued...
Old 04-01-2006, 12:16 AM   #9
1977 23' Safari
1975 31' Sovereign
the 555003 shock
1. Shock max extension is 14-3/4". Max active extension is 14-1/8". Min length is 9-5/8". It fits nicely in the space provided. My totally coarse measurements tell me that they actually have a lot of margin on both ends. The positions shown here are approximately where the shock bracket would put the shock during active axle motion. BTW, both ends of the 555003 shock take a 5/8" stud, which is exactly what my 1971 trailer provides.
Name:	IMG_4872 shock short-s.jpg
ID:	20031Click image for larger version
Name:	IMG_4871 shock mid-s.jpg
Name:	IMG_4873 shock long-s.jpg
2. I include these photos to show the position of the old axle, like pretty much dead level or down a little. (Nice shock, yes?) For those contemplating replacing an axle, note the flange relief at the axle pass-through. If you have a 60s trailer, you'll want to make sure your axle bracket is welded on the side away from the jacking plate so that you don't create a weld bead that interferes with a close fit of the jacking plate to the bracket.
Name:	IMG_4866 old shock-s.jpg
ID:	20034Click image for larger version
Name:	IMG_4859 drum and shock-s.jpg
3. Due to an upcoming trip, I don't have time to fiddle with the shock location. However, note that there is plenty of room to mount the shock bracket under the axle swing arm and a bit aft (and still run flat without hitting the ground with the shock), so that clearance can be provided for an almost vertical installation (this experiment to be performed later this year on the Overlander, along with disc brakes). There is a Monroe shock in the same series as the 555003 that is shorter, if required. But the real reason is not for installation of the more available vertical shocks, but to allow shock removal without having to drop the axle (yes, Andy can show you how to bend the bracket so you can get the shock off, but ick inelegant!)
Name:	IMG_4859 drum and shock-sm.jpg
It may be a couple of days before I trial fit the new axle. I happened to stumble on sneakinup's photos today and am now compelled to open up the belly pan and take a look. Sheesh.
Old 04-01-2006, 12:39 AM   #10
S C Streamer's Avatar
Profile:  1964 17' Bambi II
Santa Cruz , California
Images: 13
Thanks Led:
Your thread on the axle replacement is great, job well done. I'll be replacing the axle on my Bambi II next month and this sure helps a lot.
Thank you for all your effort,
Mark
S C Streamer is offline   Reply With Quote
Old 04-01-2006, 06:11 PM   #11
1977 23' Safari
1975 31' Sovereign
belly panel off
whoever said that the more you take apart the more you have to take apart was absolutely right. On close inspection, my belly panel was held on by about three rivets and two screws; everything else had pulled through. The axle was keeping the leading edge up and a couple of overlapping side skins were holding the mid section. Good thing the skin was tucked into the lower flange of the bumper (making up the bumper stowage). I was thinking of repairing the holes, but I think I'd rather remodel so that the belly skin only covers the belly. I'll make up the stowage area with a small strip of heavier guage skin.
What was found? Well, 80% of the insulation was still up against the floor. The section that fell down and was in contact with the skin, about 2x3', was wet and had to have been wet for a couple of months (or frozen, actually). The condition of the ribs was good to fair, with only slight rust on the forward frame members, increasing to moderate rust as you go aft. I see one broken frame, but it's not where a rivet hole was--just an otherwise undamaged section. No indication that there was a blow from below. Hmmm, maybe I better correlate a penetration in the skin, could be...
I'll start with the wire wheel tomorrow and hopefully be ready to use Metal Ready by Monday. Got to get this hummer back together by Friday.
Here you can see the belly skin. Doesn't look too bad, but there have been some previous repairs where a PO cut the skin back for other repair work, and all the existing rivet holes are pulled through to 3/8" diameter. You can also see the remaining insulation (it was installed prior to the frame! and so is compressed under the frame members). The frame break is not very apparent, but it's totally through the bottom of the lightening hole. The view is approximately parallel with the axle, from just about a foot aft.
Name:	IMG_4881 belly pan-s.jpg
ID:	20053Click image for larger version
Name:	IMG_4884 fwd little rust-sM.jpg
One thing to note in the photo above!! Where the drain pipe passes across the frame member, it is rubbed almost completely through, like a wide knife cut. Another trip or two and it would have been penetrated.
The rust in the rear is significantly worse. You can't see it in the photo, but the floor right at the most aft frame member is water damaged, but even though a layer has delaminated, it's still stiff--no need to replace it yet.
Name:	IMG_4887 other corner rust-s.jpg
ID:	20055Click image for larger version
Name:	IMG_4888 rear corner rust-s.jpg
Old 04-02-2006, 07:41 AM   #12
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
Belly Pan Removal
Ah, such fond memories!
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 04-02-2006, 08:31 AM   #13
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Ok, tell me again why I need to replace the axels on my trailer because it's a 58. I've had so many different opinions. Some say you "have " to, some say to just look at them to see where the trailer rides on them. I just brought this trailer home and from looking, and pulling, it seems fine. It has the leaf springs, which also look to be in great shape. I'm confused.
juel is offline   Reply With Quote
Old 04-02-2006, 08:57 AM   #14
1977 23' Safari
1975 31' Sovereign
Leaf springs? I've only seen a few examples. I'm replacing swing arm axles, which is the type of suspension on Airstreams from before (?) about 1964 to present. With your suspension, your biggest issue is good shocks (as it would be on any vehicle with leaf springs). Also, we all check and repack the wheel bearings a lot more often than you would on a car or truck.
High on the list would be checking your brakes. I've had three of the originals fall apart internally. The easiest fix for old brakes is to buy new brake plates, about $50 each. There are other threads showing how to take the old ones off and bolt the new ones on. It's a pretty simple, dirty, knuckle-busting, half-a-day job. Besides the reward of getting reliability up, you can't find the old magnets, so you eventually have to replace the whole brake plate anyway.
The reason we all "debate" replacing our swing arm axles is that even bad axles seem to tow well. The problem is that they beat the snot out of the trailer because they become either so hard they are "frozen" or they eventually creep up to the top stop. Either way, it's a hard ride. Did I say hard? How about damaging?
Even though mine still had a slight down angle (arm angle is the criteria most cited--a new axle starts at 22.5 degrees down), I was breaking door shelves in the fridge from the sharp forces transmitted by my old axle. If the trailer sits for a few years, the rubber in the torsion tube hardens, which is the end of that axle as a ride softening device.
Now, back to the project....
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 08:15 PM
Who made my axle? Pahaska Axles 44 07-25-2007 11:08 AM
Duratorque Axle Replacement Andy R Axles 12 04-28-2005 10:26 PM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 06:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 10:35 AM
