Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 05-02-2006, 08:20 PM   #99
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Ever hear the phrase "you can't cheat an honest man"? I've always thought it best to walk away from a fast talkin' salesman, unless there was absolutely no other option. In such a case, procede with extreme caution.
There's a lot of wisdom in those that came before us.
Can somebody remind Susan that I really do want bagpipes for Christmas?
www.nesa.org
Air No. 6427
Old 05-02-2006, 10:49 PM   #100
Commercial Vendor
Profile:  Currently Looking...
Somewhere , Indiana
Originally Posted by StingrayL82
Henry,
As always, thank you for the compliment. A former Command Sergeant Major once complimented me on the fact that I, "....take no sh!t, but realize how to fix the problem with tact". I don't know about the tact part, but my axle problem needs fixing; that's a fact I do know, and it will get fixed.
Frederic
Frederic,
You're welcome!
That's a cool compliment! I too dig straight shooters! I like to consider myself one of them.
If I can be of any assistance in your axle venture - simply let me know. Drop me a PM if you like - I'll help you any way that I can.
Best Regards,
Henry
axleman is offline   Reply With Quote
Old 05-03-2006, 01:45 AM   #101
Profile:  1992 34' Limited
Falls Church , Virginia
Straight shooters and the like....
Hello all -
I consider this forum to be nearly all 'striaght shooters' when it comes to help, advice and assistance.
There is however 'rough waters ahead' the minute $'s get introduced to the equation. It is NO different in any other phase of life however.... Still one would like to think that ASin, and AirStreamForums is different.
Au Contrair!
Whenever I see a $ motive, I immediately get sensative to 'BS' and the like.... And there is plenty to 'dis' like....
I have had terrific advice, help, photos, assistance, offers of help, warnings and plenty more from folks that have 'no dog in this fight', no financial gain or any other obvious motive - other than to help with something I or others have asked about.
For all of them, I am thankful and say a HEARTY "Thanks"!
For the others that have motives, financial or otherwise, I also say "Thanks, but a qualified one" - very qualified. Not that that info is less valid, correct or otherwise instructive - I just have to filter to understand it clearly.
A few thoughts. Anyone want to add anything?
Axel
SilverToy is offline   Reply With Quote
Old 05-03-2006, 09:15 AM   #102
Commercial Vendor
Somewhere , Indiana
Good advice!
Jim & Axel,
That's good advice. Enough said!
Regards,
Henry
Old 05-16-2006, 02:45 PM   #103
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
removing the drums
Help! This axle uses a new method of retaining the castellated nut. Instead of a cotter pin, there is a flat spot on the spindle with what looks like a tabbed piece of metal stuck in and bent over, with one tab through the castellations (photos to follow). Anyone know the proper method of removing this? It looks like you just pull it straight out.
I assume that any parts place has replacement tabs?
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com www.pygmykayaker.com
Old 05-16-2006, 02:55 PM   #104
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
If it is what I think it is the nut has a metal piece that fits over it. And it is bend into the flat area after the nut is tightened to the proper spec. Reuse of the metal piece is discouraged.
So having a supply of them is a need.
>>>>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 05-17-2006, 06:07 AM   #105
Commercial Vendor
Somewhere , Indiana
Tang Washer!
Hey Zep,
It's called a tang washer. This is used with the safe-t-lube spindle option. Very inexpensive and easy to replace. Your spindle is ported to add grease to the bearings, thus a cotter pin (if used) would go through this port.
I would replace!
Regards,
Henry
Old 05-17-2006, 09:41 PM   #106
1977 23' Safari
1975 31' Sovereign
much news, so probably several posts.
first, I got the Centramatics. I was surprised to see that there were two different types. The one with the offset is to allow for disc brake caliper clearance. Either style fits nicely inside my 15" X 7 alloy wheels, even with two layers of weights on the inner surface (the other wheel had three layers, but I had the mechanic move the third layer). Three layers was just too close, although it may have barely fit (no contact between Centramatic and wheel is allowed--I interpret that to be "or anything on the wheel"). The Centramatics can go on the hub "face out" or "face in". I think this might be important if you have steel wheels, but the alloys all seem to have the right depression of "spokes" that allow plenty of room.
What's the down side. Well, none.
Except for me, that is. Remember my axle was manufactured for a lower weight rating than needed, so the the swing arms are up a couple of degrees? This put the shock near its upper limit, so I ordered the 555002 (about 2" shorter) to make sure the shocks didn't bottom out if the axle did. I only intended to use these shorter shocks until I got back to Colorado from Vegas. When I got home, I discovered the shorter shock didn't allow the swing arm to swing all the way down, so I had interference when trying to remove the wheel--had to pull the wheel off, then the wheel got caught on the top of the Centramatic, so had to hold the wheel up a little and wiggle the Centramatic off the studs. Not a big deal, just an aggravation. This won't happen with the normal shock, since the arm will swing down far enough to allow easy removal of the wheel.
Name:	IMG_5071 two disks-s.jpg
ID:	21408Click image for larger version
Name:	IMG_5074 on hub-s.jpg
Name:	IMG_5076 on hub-s.jpg
ID:	21410Click image for larger version
Name:	IMG_5078 face out-s.jpg
Old 05-17-2006, 10:17 PM   #107
1977 23' Safari
1975 31' Sovereign
I dissassembled the axle in preparation to return it, to correct the weight problem. As part of this, I had to opportunity to check the bearing grease. The wheels on this axle ran significantly warmer than my truck wheels, even though all wheels supported very nearly the same load. I estimate the truck wheels were running around 95 degrees and the trailer wheels something less than 30 degrees warmer. At one point, I jacked up the trailer and readjusted both brakes to ensure they weren't dragging. After this, the temperatures remained warmer (but not hot--I could put my hand on the wheel, even though I wanted to move it after about 5 seconds).
The bearings were adequately packed (I was afraid that they lacked sufficient grease, since putting too much grease in through the safe-T-lube fitting could force grease into the drum and ruin the brakes--being too careful on that aspect and not putting in enough grease could result in hot bearings), although I wouldn't call them fully packed--maybe 75% packed. But that wouldn't cause the temperature to rise, IMHO. Some of you smart suspension persons might want to comment on this. Thanks.
Name:	IMG_5275 grease void-s.jpg
Here's a shot of the disk retention system that replaces the cotter pin in a safe-T-lube spindle.
Name:	IMG_5273 disc with nut-s.jpg
ID:	21412Click image for larger version
Name:	IMG_5274 disc-s.jpg
A comment on the safe-T-lube: I have alloy wheels, which have a cone in the center that covers the spindle. This requires that I remove the wheel in order to get to the grease fitting. Heck, once I have the wheel off, it's not that big a deal to go ahead and remove the hub and pack the bearings by hand. When combined with the risk of forcing too much grease into the hub via the grease fitting and forcing grease past the seal, ruining the brakes. So I think if you have alloy wheels, take a pass on the safe-T-lube.
One thing that surprised me is that the swing arms didn't return back to a 22.5 degree down "no-load" position. You can see from the photos that the no load angle was about 18 degrees down. On the other hand, they appear perfectly symetrical.
Name:	IMG_5282 curb side-s.jpg
ID:	21414Click image for larger version
Name:	IMG_5281 street side-s.jpg
So, the bottom line is, Axis missed the weight bearing spec somewhat, but everything else appears to be perfectly matched--the loaded angles, the run-in no load angles, the temperatures--all were matched side-to-side.
Old 05-18-2006, 12:42 AM   #108
Moderator dude
Action's Avatar
Phoenix , Arizona
Images: 13
A Big Thank You for all of the detail!
>>>>>>>>>>>>>>>>Action
Old 05-18-2006, 08:19 AM   #109
Commercial Vendor
Somewhere , Indiana
=Zeppelinium
Hey Zep,
Nice detail man!
Just my two cents, most wheel manufacturers offer an open center cap to be used in conjunction with the safe-t-lube option.
The option is very popular, about 65% of Axis customers order the feature. That does not indicate what you should do - simply what the masses prefer.
Regards,
Henry
PS: Nice detail man!
Old 05-18-2006, 10:42 AM   #110
Commercial Vendor
Profile:  Corona , California
Torsion arms.
Torsion arms should always return to their starting point, unless they are many many years old.
If they do not, especially when relatively new, when all the weight has been removed, that would suggest that the rubber rods have already taken a set.
If the rubber rods have already taken a set, then it would be very prudent to monitor that condition, very frequently.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 05-20-2006, 03:01 PM   #111
Me loves da little twinky
Rivka's Avatar
Profile:  1971 18' Caravel
Fort Lewis , Washington
Send a message via AIM to Rivka
Axis no longer making Airstream Axles!!!
I was in the final planning stages of ordering a new Axis axel for my '71 Caravel ironically when we got this email:
As of 5/19/06, Axis Products will no longer take orders for Airstream
axles. Because Airstream axles come in many unusual configurations and
require many different custom components, we simply cannot continue
providing these specialty axles. We will continue to provide standard
leaf-spring and torsion axles. Please feel free to contact our sales
staff if you believe the standard axle configurations may work for your
application. We at Axis Apologize for any inconvenience and wish you all
well.
Sincerely,
Chad Backert
Sales Manager
Axis Products
Guess we finally drove them crazy, or the old Airstreams did. This is a sad thing, as the less choices we have the worse it sure is.
Zepp, i hope everything with your axle turns out good and you can ride off into the countryside with probably the last Axis custom axle ever made. (I assume they are still finishing yours????)
Seeing as we have the same trailer, I have been following closely and really hoped to just order "I'll have what he's having" style at the end of it all. I will have to look to another maker but will eager wait to hear your outcome and advice.
Rivka is offline   Reply With Quote
Old 05-20-2006, 03:45 PM   #112
Rivka's Avatar
Hey Zepp, can you tell me your/our wheel bolt pattern? I am 3000 miles away from my girl and can't find the info.
I'm going to be bringing her new wheels and tires as a gift for the tow home.
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 08:15 PM
Who made my axle? Pahaska Axles 44 07-25-2007 11:08 AM
Duratorque Axle Replacement Andy R Axles 12 04-28-2005 10:26 PM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 06:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 10:35 AM
