Old 07-15-2015, 01:33 AM   #15
1954 22' Flying Cloud
Kirkland , Washington
A drop axle is probably going to be the only appropriate action given the space you have to work with. Reason I know is that I made the conversion to straight axle this month on my 1954 Flying Cloud. Check to see how much travel your suspension has before bottoming out, that will determine if spacers will even be possible. As for my setup, I just pulled the original drop axle in favor of a straight axle and the added height. In addition, had the springs re-arched to get another inch and 1/4. That part was necessary given the three inch clearance to bottoming out was reduced by an axle a full inch taller. Rule of thumb: You want to have a minimum of three inches space for spring travel. Although less may suffice, having an axle slam into the frame can't be a good thing. A good suspension shop will take your leaf packs apart, inspect and clean them up. If they're not heavily rusted they'll give you many more years of service, and the 36 inch length is favorable to anything shorter as they provide a smoother ride and spread the impact as the trailer was designed.
54fuselage is offline   Reply With Quote
Old 07-16-2015, 06:01 AM   #16
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
I have plenty of space for spring travel, but it turns out my shock mount is welded to the bottom of the spring so I cannot easily add a spacer...
BambiTex is offline   Reply With Quote
Old 07-16-2015, 07:17 AM   #17
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Be sure that after adding a lowering block the axle will not hit the bottom of the trailer when going down the road. That being OK, install lowering blocks using longer U bolts. The distance between the lower and upper shock mounts will remain the same. What will change is the distance between the top of the axle and the bottom of the trailer, which is what you are after.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 07-16-2015, 09:34 AM   #18
1981 31' Excella II
New Market , Alabama
Looks like the po cheaped out and did not put a drop axle on to replace the original.
You may have to spring for a new axle. How about posting a photo.
Perry
Old 07-20-2015, 06:59 AM   #19
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Turns out bottoming out would be an issue. Axle is currently three inches below frame so a 2 inch spacer would leave too little clearance. Also, shock absorber is mounted below leaf spring - see attached pic.
Old 07-20-2015, 08:14 AM   #20
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You have a Bambi with what appears to be 7+ leaves in that leaf pack. It appears this vehicle is set to handle a full load of masonary. The easy fix would be to remove 2 to half of the leaves go get the proper ride qualities. This vehicle is over sprung!
>>>>>>>>>>Action
Old 07-20-2015, 09:58 AM   #21
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Wrong trailer
>>>>>>>>>>Action
That is actually my Flying Cloud. I agree the leaf springs seem oversize. Not sure I am remove leaves though without bottoming out. More info earlier in this thread...
New leaf springs shorter than original - what to do? Airwave503 Axles 3 08-27-2014 01:00 PM
Who has a 2" drop with leaf springs? TravelCloud Axles 3 04-14-2005 01:06 PM
Leaf Springs & New Axle MarkR Axles 10 02-17-2005 01:12 PM
Leaf springs markdoane Axles 2 09-27-2003 11:26 AM
Leaf Springs ALANSD Airstream Motorhome Forums 7 09-26-2003 11:55 AM
