Old 04-05-2015, 09:33 AM   #1
jmhansen's Avatar
1977 31' Sovereign
Margate , New Jersey
Need 3 inches of height!
We have a 77 airstream sovereign that we completely gutted and rebuilt. We installed bigger waste tanks that caused the drain pipe to have to be about 4 inches lower then it was before - now we have the release valves coming up through the bumper instead of through the back compartment. We used a drop hitch to get it to toe level but it still hits the drain pipe when we go over bumps and hills. We replaced the axels but not the leaf springs. Would installing new leaf springs give us about 3 more inches? Or any other suggestions?
Musical Traveler
jmhansen is offline   Reply With Quote
Old 04-05-2015, 02:10 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
A 1977 doesn't have leaf springs. It has rubber torsion springs inside the axle assembly.
That is a tall order to raise it by 3 inches.
And there may be users that have suggestions.
Mine wold be taller tires and that will only get part of your 3".
>>>>>>>>>>Action
Old 04-05-2015, 03:11 PM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Your trailer doesn't have leaf springs. All Airstream's built after 1960 used rubber torsion axles. The torsion arms were all preset at the factory at 22.5 degrees (except for a few late model small Sport models that have 10 degree arms). Most of my clients request the original torsion angle, however there are a few who want a little more clearance. In this instance we order axles with 32 degree torsion arms, which gives 1 1/2" - 2" greater ground clearance than original.
Colin
Colin H is offline   Reply With Quote
Need 3 inches of height! adonh Jacks, Stabilizers, Lifting and Leveling 7 04-05-2015 03:18 PM
Hitch Height vs. Ball Height adamwright Towing, Tow Vehicles & Hitches 5 02-12-2015 03:24 PM
Need some 12 inches backing plates and drums VeggieBullet Brakes & Brake Controllers 6 09-04-2014 07:34 AM
How to raise the height of the toilet a couple of inches? aquinob Sinks, Showers & Toilets 3 01-12-2013 01:23 PM
