Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 07-08-2014, 11:11 AM   #1
1957 22' Flying Cloud
Bozeman , MT
Need 1953 35" replacement leaf spring or ???
Has anyone found a source for replacement leaf spring for 1953 21' Flying Cloud Single Axle. Double Bolts 35" from center of bolt to center of bolt. Or has anyone added a coil spring or ??? Axle is about two years old, but after bouncing 5000+ miles this summer, leafs are sagging and need replaced. Here are a couple pictures. Thanks Terry tlcbuilder@aol.com
Streamer1492 is offline   Reply With Quote
Old 07-08-2014, 11:12 AM   #2
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
Red Neck Trailer Supply
Jim Lee is offline   Reply With Quote
Old 07-08-2014, 12:08 PM   #3
1974 Argosy 20
Kooskia , Idaho
Many cities have spring shops which will custom make anything you want, need, or can even think of. Common and not expensive at all.
Old 07-08-2014, 12:11 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Just do a search for spring shops in Vegas .... Here is one.
Skips Spring Service
5310 Procyon St,
Las Vegas, NV 89118
(702) 997-0517
Or if you know the dimensions - length, width, leaf count and weight needed to support the load you can have a set built. I had a set built by a builder in Florida or Georgia and had them shipped to Phoenix for less money than a local shop. It was done for the rear axle of my van however the concept is the same no matter what the vehicle.
>>>>>>>>>>>>>>>>Action
Old 07-17-2014, 07:55 AM   #5
1952 21' Flying Cloud
salt Lake City , Utah
I have a 1952 Flying Cloud which I plan on converting to a dual axle. I could sell you my springs in the fall. Will
WillJamison is offline   Reply With Quote
Old 07-18-2014, 02:40 PM   #6
Bozeman , MT
Thanks to all, found a spring company Swains Spring Service in Great Falls, Montana and he made new ones for me. They have been in business since 1885 and have all the tools. He said he was the last shop in Montana that will make them, don't know if that's true, but they did a great job and fast..
Torsion vs. Leaf Spring Axles twisteda Axles 20 03-17-2009 04:07 PM
Leaf spring suspension grommets Scott S Axles 10 06-02-2008 07:26 AM
Leaf Spring Assist for my TV VSP Raleigh Tow Vehicles 2 01-12-2007 03:14 AM
How many leaves in a leaf-spring axle??? 1959newbie Axles 20 08-05-2006 04:53 PM
