Old 07-18-2014, 03:26 PM   #1
1970 31' Sovereign
Gastonia , North Carolina
Mystery Axle Installation
I'm knee-deep into a shell-off restoration of my 1970 Sovereign 31'. I noticed something odd about the axles. Both curbside axles are snugged up to the bottom of the main beam. On the other side there are spacers on the rear and a gap on the front. Is this normal? Will it affect the new axles?
One thing I'm noticing is that there seems to be a lot of variations depending upon who was working in the factory that day and what mood they were in. LOL
ID:	216658   Click image for larger version
ID:	216660   Click image for larger version
drchris66 is offline   Reply With Quote
Old 07-18-2014, 03:34 PM   #2
dznf0g's Avatar
Oswego , Illinois
I would be interesting to see if the spacers are welded or bolted in, or if the others have vibrated out. And the curbside has just slipped upward due to roadside potholes. Are the holes slotted?
-Rich-
Old 07-18-2014, 04:39 PM   #3
Airstream turned the bare chassis upside down, then installed the underbelly and other goodies.
They also installed the axles when upside down. That's why the aluminum is sandwiched in.
The axle is mounted with 2 5/8 bolts to the axle mounting plate.
The axle data plate should show that the rating was 3200 pounds each.
Old 07-18-2014, 06:14 PM   #4
1970 31' Sovereign
You are right. The hole in the frame is fixed but the holes in the mounting plates are oblong allowing movement up and down. I guess thats one way of getting an extra 1/2 inch of lift.
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
Dexter axle installation Inland RV Center, In Axles 22 09-20-2013 04:27 PM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
Revolutionary new axle installation procedure, aka what am i missing? chrisd37 Axles 54 04-15-2009 10:33 AM
Dexter Axle Installation Started! Streamin 65 Axles 17 06-07-2006 04:02 PM
