Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 10-01-2009, 10:17 PM   #1
wayne.yl's Avatar
Profile:  1977 31' Sovereign
1992 34' Excella
Salem , Oregon
mysterious damage to endcaps
There are mysterious cracks in the ends caps of my 1992 34ft trailer.
The cracks are located where the face of the oak cabinets join the end cap at both the front and back of trailer. Could this be a result of excessive vibration from worn out axles? I have checked the axles and they still show some life according to the axle test recommended by inland rv. When jacked up the wheels drop 2-3 inches before coming off the ground. I have replaced the tires on the trailer as well. Just don't want to buy 3 new axles unless I need to but don't want to lose the oak cabinets either.
Thanks much.
WP
"The significant problems we face cannot be solved at the same level
of thinking that created them." -Albert Einstein
wayne.yl is offline   Reply With Quote
Old 10-01-2009, 10:30 PM   #2
Airstream01's Avatar
Profile:  2008 25' Safari FB SE
Virginia Beach , Virginia
Photos?
Airstream01 is offline   Reply With Quote
Old 10-01-2009, 10:35 PM   #3
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Just guessing.
Hi,
Running gear out of balance?
Overloaded cabinets?
Normal with age?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 10-01-2009, 10:33 PM   #4
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Have someone tow you down a not too smooth road while you ride in the trailer. In particular look for something moving that shouldn't or moving on one side and not the other, like the bulkheads.
Pay no attention to the man behind the curtain- WoZ
Old 10-01-2009, 10:36 PM   #5
Mike Leary's Avatar
Profile:  On the move , Las Cruces, NM
What do you mean by "cracks". Pics, please.
1983 310 Turbo Diesel Mo/Ho "Bess" 212,835 miles
Full timing since 1994
Mike Leary is offline   Reply With Quote
Old 10-01-2009, 11:03 PM   #6
Commercial Vendor
Profile:  Corona , California
Thanks much.
WP
Two things can cause those cracks.
The first is a very hot climate.
The second is vibration.
Sources of vibration are one or more of the following.
Excessive rated tow vehicle.
Excessive rated hitch bars.
Out of round tires.
Bent wheels.
Unbalanced or improperly balanced running gear.
Bad shocks.
Any torsion type axle can cause bottoming out issues. If the drop is 3 inches as you tested, then check the torsion arm or trailing arm for proper position, when the trailer is loaded for travel. If it's correct, then the axles are not a part of the problem.
Excessive rated tow vehicles and/or torsion arms, would also usually cause shearing of rivets, both inside and out.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-11-2009, 11:40 PM   #7
wayne.yl's Avatar
1992 34' Excella
Salem , Oregon
cracks in endcaps
Sorry it took so long.
My mother-in-law passed recently and we have been travelling.
Anyway, these are the cracks I was describing. It may be hard to see but they are in the upper right corner where the cap connects to the oak cabinet. It looks like the weight of the cabinet is part of the problem but I am not sure.
any thoughts??
wp
Name:	cracks in endcaps 92 excella.jpg
Old 11-12-2009, 02:44 AM   #8
Commercial Vendor
any thoughts??
wp
It's not likely the cabinet had anything to do with the cracks.
Read post # 6 above.
Andy Rogozinski
Inland RV Center
Corona, CA
Mysterious plug DUNSKI Lights - Interior & Exterior 10 04-10-2009 11:28 AM
mysterious odor sparky5 General Repair Forum 15 01-21-2008 02:39 PM
Cracks in endcaps...and more Tin Lizzy General Interior Topics 1 08-14-2007 04:25 AM
'59 fiberglass endcaps 1959newbie 1958 - 1963 Overlander 14 12-14-2006 08:26 AM
Has anyone fabricated new endcaps? soldiermedic Upholstery, Blinds, Walls & Interior Finishes 7 11-17-2006 06:41 AM
