Old 05-10-2011, 12:27 AM   #99
Alignment of an axle is not necesaary when the trailer is a 1968 and newer.
The bolt holes take care of that for you.
From 1967 and older, you measure from the "CENTER" of the jack post, to the lower forward corner of the axle mounting bracket.
That dimension must be exactly the same.
By actual measurement, 1/8 of an inch off will make a 31 foot trailer, tow dog leg by 3 inches. 1/4 inch will make it tow dog leg 6 inches.
Towing a trailer dog leg, causes huge wear on tires, plus making the trailer tow with a large degree of instability.
I know, I had one with a 3/8 inch difference. It towed dog leg 9 inches.
The difference can be realigned back into the axles, if the shop knows how.
Old 05-10-2011, 05:05 AM   #100
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by Globie64 View Post
All this information is great to have- I'm wondering how to decide what kind of axle to specify, or if it really matters between manufacturers. It seems pretty straight forward to install, what about alignment once the thing is back together?
Originally Posted by Top View Post
For alignment, measure between each hub and the center of the tongue jack. They should be within 1/8" If not adjustment is necessary.
ok, easy enough. thanks
For your little Globetrotter, precise alignment isn't necessary, since you only have the one axle. Your 1/8" alignment will be "close enough". At worst, the trailer will track maybe an inch out of straight, and won't wear the tires funny, since you only have one per side, and they won't be working against each other.
Old 05-10-2011, 06:22 AM   #101
soldiermedic's Avatar
Florissant , USA
+1. Single axle, small trailer, good enough...now GIT R DONE!
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 05-12-2011, 10:11 PM   #102
Trex's Avatar
1981 20' International
Shasta Lake City , California
TOP, Trailer of Personnel... thanks for the intel today on the phone. Thanks again,
"Sometimes you eat the bear, and sometimes, well, he eats you." -the Stranger-
Come and see me at: http://www.airforums.com/forums/f185...-71804-60.html
Trex "Airstream Nomad"
Trex is offline   Reply With Quote
Old 05-13-2011, 08:18 AM   #103
Originally Posted by lahrfarm View Post
Where did you get these numbers? They dont really sound like "brake stoping power" numbers. They sound sound more like GVW per axle numbers. I've never heard of anything being engineered to do the minimum with no safety designed in. What I am saying is a 3500# axle doesnt fail at 3501#, so why would they design the brakes to do just that. If they know we wont adjust them, and they put in wrighting,
"At 50 percent, 10 inch brakes can then properly stop 1750 pounds per axle, and 12 inch brakes can properly stop 3100 pounds per axle", then they would get sued everytime one failed.
The numbers come from the brake manufacturers catalogs.
All electric brakes will fade when they get hot enough.
That being the case, check 10 inch and 12inch brakes on the same size trailer, and see how fast the 10 brakes fade out.
Amazing observation.
Old 05-13-2011, 08:52 AM   #104
CanoeStream's Avatar
St. Cloud , Minnesota
Andy, based on circumference, a 12' brake has 1.2 times the circumference of a 10". That is not inconsequential and certainly gives an extra margin for those inexperienced enough to be using their brakes that much. I'm glad to have a tranny as controllable as my Allison, but gearing down should be available to any competent tow vehicle as the first resort.
I know that 12" vs. 10" is part of the discussion for replacement axles; ie, Henschen spec'd vs. Dexter vs. Axis. The answer I've never seen is: Jackson Center is installing Dexters on new Airstreams. Are these 10" drums?
5 meter Langford Nahanni
Old 05-13-2011, 09:56 AM   #105
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
10 vs 12: do the bigger brakes require new rims? I'm imagining that a new axle will make tire changing a LOT easier, but the bigger brakes might make it more difficult? I mention this after having to change tires twice and having to let air out to get them in and out of the wheel well. This would be less of an issue except for the nearest gas station with air is 10 miles away. Fortunately I was able to use the compressor at the nearby corporation yard for our area, but what a colossal pain, I can't imagine doing it on the road.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 05-13-2011, 10:22 AM   #106
12 inch drums weigh 33 pounds and 10 inch drums weigh 22 pounds each.
That in itself, says the 12 inch drums have much more surface to dissipate the heat generated when braking, than the 10 inch drums.
SAFETY is the real issue, first and foremost and then stopping power.
Seven inch brakes are also available for those that wish to down size.
What Airstream may do with brakes today, is dictated by Dexter, not Airstream.
Old 05-13-2011, 11:01 AM   #107
Globie64's Avatar
Images: 18
Andy, I'm with ya on the brake size- larger brakes give you reserve capacity and a better margin of safety.
Old 05-13-2011, 11:56 AM   #108
Bad axles make tire changing difficult, never the size of the brakes.
Of course changing 14 inch wheels to 16 inch wheels, will make it more difficult, as well.
Old 05-13-2011, 01:52 PM   #109
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
So, is JC puttin' 10" or 12" on todays airstreams?????
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 05-14-2011, 08:57 AM   #110
They are using both, depending on the model.
Old 05-19-2011, 07:11 PM   #111
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
The finished product
I have Abby's axles all installed and she's off the jack stands so I took a picture to show the change in ride height.
Before. December 2010.
After
She should be smooth as silk!
Lance
Top is offline   Reply With Quote
Old 05-19-2011, 08:36 PM   #112
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
That's quite a difference, Top. I look forward to seeing all of your hard work at the rally.
Bruce
axis, axle, henschen, measurements, dexter axles
Video - Successful Axle Job on 1964 Safari JitneyBead Axles 10 05-21-2012 09:07 AM
