Closed Thread
Old 11-20-2005, 09:50 AM   #1
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I picked up a pair of new axles from Axis a couple of weeks ago but due to the weather and other commitments I didn't get around to installing them until today. When I looked at them I realized that the new axles are not the same as the old ones.
The brackets appear to have been put on the wrong ends so they extend more to the back, but on the old axles the brackets are longer to the front of the axle.
The distance between the brackets is 1/8" greater on the new axles. The brackets on the axles have to fit between the axle mounts on the trailer and since the old axles were a tight fit I think this extra 1/8" would make it very hard to get the axles into place.
The distance between the mounting plates for the brakes is 3/4" less on the new axles, which I think means the tires would be 3/4" closer together.
How could they get this so wrong when they had the old axles to copy from? I'm glad I brought the old axles home, but I wish I'd looked at the new ones more closely when I picked them up.
I'll be calling them tomorrow to see how they can fix this problem.
ID:	16493   Click image for larger version
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline
Old 11-20-2005, 09:54 AM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I am VERRY suprised to see that from Axis, I wonder what they are going to say when you contact them. My guess is they will do what they need to do to make things right. Bummer that you are having to suffer through this though.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline
Old 11-20-2005, 11:51 AM   #3
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Hi Grant, I noticed they didn't put the shock mounts on the new axles either. What I would do before I call them is make sure everything else fits, backing plates, drums, bearings etc. If none of the hardware fits they may as well get you a new set of axles. I feel your pain man, hope everything works out in the end.
Chris
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline
Old 11-20-2005, 12:16 PM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Chris
There are shock mounts. They don't have a stud, though. Look at the first picture....but regardless, the shock mounts are useless, because in order to use them you will have to put a bolt through the top hole in teh shock mount. This bolt will promptly interfere with the axle mounting bolt, which will sit right behind it.
I would return these axles, and have them make "proper"ones for you. This case is especially laughable, since you apparently provided them with sample axles......
Uwe
www.area63productions.com
uwe is offline
Old 11-20-2005, 12:22 PM   #5
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Uwe, You are right ! I see the shock mounts now. I agree take em back.
Project 2k5
Old 11-21-2005, 01:13 PM   #6
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Mounting plates on wrong ends?
Grant: To me, it looks like AXIS mistakenly welded the correct size new angled mounting plates on the wrong ends of your new axle, as you have already mentioned. Imagine lifting each plate off, turning it 180 degrees, swapping them end to end across the axle and then welding them in place. The new 90 degree angled mounting plates should then fit just like the old ones on your original axle. Seems to me a simple "wrong side" mistake by the mounting bracket welder that wasn't caught before your axle was shipped. Human error sometimes happens. I imagine AXIS will be more careful second time around.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline
Closed Thread
Upgrading/replacing axles? mcneon Axles 18 07-14-2004 04:48 PM
How many axles replaced Jabba Axles 7 10-21-2002 01:21 PM
Axles on a Avion 68 Suburban Axles 0 10-06-2002 12:10 AM
Will this couch fit my trailer?? JohnGalt48 General Interior Topics 4 08-07-2002 06:38 PM
Motor Home Tag Axles - winner General Motorhome Topics 0 05-25-2002 04:56 AM
