Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 07-31-2007, 05:42 PM   #1
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Are my axles shot?
I've done some research on axles and from what I can gather, it seems I will need to replace both the axles on my '61 Ambassador. With the trailer now completely empty, I took a look at the torsion arms and it isn't a pretty sight. The torsion arms on one axle are at a zero degree angle and, on the other axle, the torsion arms have an upward or positive angle (see attached photo).
What do you axle experts out there think?
WBCCI Region One
"Repression provides a temporary solution." ~ Paul Williams
yukionna is offline   Reply With Quote
Old 07-31-2007, 06:07 PM   #2
C Johnson
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
I'd say they are shot. However, they are 46 years old. I would replace them even if the angles looked ok. The rubber rods in those axles has more than likely taken a set. Meaning no more flexibilty. The useful life of those axles is just about over.
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Blog Chris' World
My Pictures
C Johnson is offline   Reply With Quote
Old 07-31-2007, 06:19 PM   #3
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Yea, I agree, new axles are in your future.
Was this the one used for mobile storage/junk that you posted about earlier, or was that you?!
Old 07-31-2007, 06:30 PM   #4
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
The axels look like the trailer has been sitting for years in a field with about 2000 pounds of trash inside of the trailer.
Richard
Charter Member Four Corners Unit
Old 07-31-2007, 06:33 PM   #5
yukionna
yukionna's Avatar
Images: 18
You got it! That's the situation!
I figured they were shot but I thought I would ask!
WBCCI Region One
Old 07-31-2007, 06:34 PM   #6
yukionna
yukionna's Avatar
Images: 18
Yes, that was me posting about the "mobile storage/junk" and it is the same trailer!
WBCCI Region One
Old 07-31-2007, 07:37 PM   #7
azflycaster
Phoenix , Arizona
Images: 58
Lucky guess!
From the looks of things I would go with the axels and new brakes. How far did you tow it like that and how did it travel?
Richard
Old 07-31-2007, 08:09 PM   #8
yukionna
yukionna's Avatar
Images: 18
We towed it about 150 miles. It pulled ok but it felt heavy. I guess it would be heavy with a dry weight of about 3500 pounds + 2000 pounds of trash!
WBCCI Region One
Old 08-02-2007, 06:55 AM   #9
yukionna
yukionna's Avatar
Images: 18
Here's another view of the torsion arm. You can see the tail end of and it has a slightly upward angle.
WBCCI Region One
Henschen Axles hex Axles 37 04-15-2005 06:27 AM
Airabelle's been shot! jeanarlene Windows & Screens 15 04-17-2004 11:27 AM
How many axles replaced Jabba Axles 7 10-21-2002 01:21 PM
Axles on a Avion 68 Suburban Axles 0 10-06-2002 12:10 AM
Motor Home Tag Axles - winner General Motorhome Topics 0 05-25-2002 04:56 AM
