Originally Posted by 62overlander
... so post 1969 is a breeze and pre 1969 can or cannot be a do it yourself and if you get lucky?... is that what I am understanding? So my overlander, being a 1962, the transition year between the leaf springs and the dyna torque, could be complicated? I have looked at my axles carefully. They are at about 8 o'clock/ 4 o'clock depending on it being front or back axle. From what I have read here, that is great. Am I wrong? If I had to change them, it would not be a matter of unbolting and re bolting or even drilling. My axles are both welded to a plate that is then welded to the frame, that plate extends at least a foot past the wheel wells in both directions. Has anyone any input on this?
Airstream did weld many axles in place in 1961 and 1962.
Cutting them off and grinding the old welds off is not a problem at least for someone that has those tools.
There still should be an "axle mounting plate" welded to the side of the frame.
To install a new axle, slip the axle in place and drill 3 each 1/2 holes thru the new axle mounting bracket and the axle mounting plate. Insert the bolts, tighten them corrrectly, and the axle installation is done.
Next would be the shock location. Because of variations back then from model to model, the shock brackets must be welded in place.
You can use the new brackets or the brackets from the old axle.
Alignment of the axle should be automatic.
There are however, every once and a while, exceptions to the alignment.
If the axle mounting plates were not installed correctly when the chassis was made, then excessive tire wear can take place. The trailer will tow dog leg, if not corrected. A 1/8 inch difference between the axle mounting plate locations, will cause about a 3 inch dog leg tracking on a 31 foot trailer. A 1/8 inch will cause almost a 6 inch dog leg on the same 31 foot trailer. The mis-location of the axle mounting plates has happened from day one, on up to at least a few of the 1972 trailers.
That is not the fault of the axle in that case, but the fault of the original manufacturing process.
The incorrect axle mounting plate placement, is rare, and can easily be checked.
To check the axle mounting plates for proper placement, simply measure from the "center of the jack post" to a shock stud, or a mounting hole, or any other point of reference, such as the leading edge of the axle mounting plates.
That dimension, "MUST" be "EXACTLY" the same. If not then the mounting holes on one side can be altered to make the dimensions the same.
When the dimensions are the same, the tire wear will be normal.
However, there are some parts of the country that have roads that have a significant "crowns." That in itself, will cause abnormal tire wear on the curb side tires. It should not be huge, but it will be more than the roadside.
