Old 11-02-2004, 12:07 AM   #1
IH Collector
IH Collector's Avatar
1963 16' Bambi
1989 29' Excella
Cumberland , Rhode Island
Mor/Ryde suspension system??
Hello,
I have become a recent owner of a 1963 Bambi. I am not familiar with the suspension system installed manufactured by Mor/Ryde. The main shock absorbing component seems to be a thick rubber spring. Was this a standard setup in 1963? Did it prove itself over time? Is it reliable and safe after 40+ years? Visually inspecting the setup, the rubber is not cracked and seems to be in "like new" condition.
After searching the forum I can see no reference to this product used in other Airstream trailers. I would appreciate any information or experience someone could share. Thanks.
Paul in Rhode Island
Paul & Melanie-1963 16' Bambi
IH Collector is offline   Reply With Quote
Old 11-02-2004, 04:15 AM   #2
LOST , Hawaii
Mor/ryde, if you haven't already found it. Documentation is here, but I don't know if it will cover anything back to '63. I have a Mor/ryde on the rear of a SOB moho and have mixed feelings about it. I like the ride but it has been pretty high maintenance and I see quite a bit more coming, rubber related. If the rubber in yours is original I would be very cautious. It can look good if it has sat much of its life but crumble when it begins to get use. Mine is 14 years old, has been used, and is beginning to show it.
John
74Argosy24MH is offline   Reply With Quote
Old 11-02-2004, 07:35 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Paul in Rhode Island!
Welcome to the Forums and the world of Vintage Airstreaming!
Originally Posted by IH Collector
Hello,
Are you certain that your Bambi actually has Mor/Ryde? If it does, it is likely a change made by a previous owner. Beginning in 1961, Airstream started using the Henschen DuraTorque Axles - - these axles are described on the InlandRV website at:
DuraTorque Axle Data
If your coach actually has the DuraTorque, you may very well find that the rubber rods have lost their resiliency which would necessitate the replacement of the axle. I know that both my '64 Overlander and '78 Minuet have needed new DuraTorques to replace their worn originals.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 11-03-2004, 07:13 PM   #4
IH Collector
1963 16' Bambi
1989 29' Excella
Hello Kevin and John,
Thanks for the welcome and the information. I will jack up the Bambi and check out the suspension system a little better over the weekend, maybe take it for a test tow to see how it tracks and handles.
I'm sure I will have additional questions as I get into the restore over the winter months.
We're looking forward to getting out camping again after many years of being too busy to get away. Time to slow down a little and relax.
Take care.
12V System....Sudden Death! Help, please Alan and Mardel Electrical - Systems, Generators, Batteries & Solar 6 12-13-2003 11:04 AM
new plumbing system Lexxy Fresh Water Systems 4 08-04-2003 10:38 AM
2002 Classic 25' suspension? Kistler 2001 - 2005 Classic 7 11-12-2002 01:01 PM
Flowmaster RV exhaust system rdm Airstream Motorhome Forums 2 07-09-2002 03:35 PM
