Old 01-06-2008, 01:20 PM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Make of axle???
This is a picture of my 1955 Safari axle, is it a HADCO axle????.........thanks
toastie is offline   Reply With Quote
Old 01-06-2008, 01:37 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Picture didn't take
Old 01-06-2008, 02:26 PM   #3
toastie's Avatar
1955 22' Safari
Originally Posted by Aerowood
Picture didn't take
Sorry about that.........
ID:	52101   Click image for larger version
Old 01-06-2008, 03:25 PM   #4
Images: 59
My guess would be yes. The knob on the outside of the upper elbow looks just like mine.
Old 01-06-2008, 04:00 PM   #5
toastie's Avatar
1955 22' Safari
Thanks, the axle's that I have seen so far from the 50's seem to be rectangle where this one is round, what years is your airstream?
Old 01-06-2008, 04:20 PM   #6
Images: 59
Mine is a '59 Tradewind. There are a few pictures in my photo album.
Old 01-06-2008, 05:54 PM   #7
toastie's Avatar
1955 22' Safari
Mark
I noticed that you put on a new axle and was wondering what was you hub to hub dim................thanks
Old 01-06-2008, 06:41 PM   #8
Images: 59
I think it was 72". I encourage you to measure yours and not use 72" as the final dimension. I paid about $120 for a 5200# Dexter axle.
Old 01-06-2008, 06:46 PM   #9
toastie's Avatar
1955 22' Safari
I will measure before ordering..............thanks
Old 01-06-2008, 07:07 PM   #10
toastie's Avatar
1955 22' Safari
Mark
Just found your post dated 10-09-2003, http://www.airforums.com/forums/f437...ment-7199.html
Plan to go with 5000# rated axle Axis Products Web will be a straight axle, should raise the trailer about 3". The Axis axle comes with a built-in brake wire to run to the other side, a nice feature.
Old 01-06-2008, 08:24 PM   #11
Images: 59
Lots of people have replaced a drop axle with a straight axle with good results.
The built in brake wire isn't that big a deal. I ended up not using that feature on the Dexter axle. I used the original grommeted holes through the frame and a junction box in the center.
If you use the wire through the axle, be sure you wire the magnets in parallel, not series. I wanted to keep the wires the same length to both magnets, can't do that with the wire through the axle.
Also, the wiring holes in the axle are possible water entry points.
Old 01-07-2008, 10:10 AM   #12
toastie's Avatar
1955 22' Safari
Mark
Looks like I will be going with a Dexter axle, talk to a local Dexter distributor
today and he highly recommended a local bussiness in my area, (about 15 min. away) I will drop off the old, pick up the new.
Steve
Do they still make these? toastie Lights - Interior & Exterior 8 12-19-2007 09:41 AM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
OK, Do they make? sjptak Our Community 14 07-01-2003 09:24 AM
They don't make them like they used to femuse Our Community 23 04-29-2003 07:15 AM
