Old 09-02-2012, 08:56 AM   #1
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 53
Major repair results - axles, shocks, tires, skylights,...
Picked up 2004 30' Classic Saturday from North Dallas RV (NDRV). Steve and Randy did an excellent job. Work included:
- Install 2 new 5000 lb Dexter axle assemblies
- Replace all 4 shocks
- Replace front and rear skylight
- Fix leaking black water valve
- Repair leaking front window seal and seals on opening windows
- Repair screen door latch
$4981.32 total. $3971 parts, of which $3503 for axles.
Randy said the original axles were 4200 each. Trailer GVWR=8700. UVW=7312.
Installed 4 new XPS RIB LT225/75R16E1 115R B plus matching spare. See http://www.airforums.com/forums/f438...ml#post1191482 As shown, plenty of room for new tires. Randy bent back ears on spare tire holder to make new tire fit properly.
Installed new TireMinder TPMS before departing. Drove 250 miles home 6 hrs with stops, max speed 65-67 mph. Started with 80 psi. Ambient temp 100 degrees or more. Max tire temp 118, max tire pressure 86.1, avg tire temps 107-110, avg pressure 83-85 psi. Rode extremely well.
Issue was so severe that on trip to NDRV, brand new Carlise tire came apart.
Looking forward to having tire blowing issue resolved and getting our trailer back on the road. :-)
ID:	167268   Click image for larger version
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Old 09-02-2012, 09:31 AM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Looks good. I just switched to 16" rims and Michelin tires. Still need to hit the road with them. Also have the tire minder, love that thing. It's fun to play with and keep track of things. And never have to worry about destroying the trailer with rubber flying everywhere.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-02-2012, 10:32 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
So you went w/ new axles AND different tires AND tpms all at once... were you just having an issue with blown tires? Were the original axles bent or misaligned and eating tires because of that? Or did you just want the increased axle capacity and did that while you were upgrading the tires?
David
DKB_SATX is online now   Reply With Quote
Old 09-02-2012, 10:49 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The OEM weight rating of the axles is not the greatest. Several people are going to 5K axles for this reason.
Old 09-02-2012, 11:01 AM   #5
gklott's Avatar
2004 30' Classic
Images: 53
Agree - what I discussed with other Airstream owners. They are quite pleased with them.
2004 30ft. Classic
Hensley/Prodigy
Old 09-02-2012, 11:07 AM   #6
gklott's Avatar
2004 30' Classic
Images: 53
Old Doran TPMS sensors died. Wanted to add temp sensor.
have gone through > 4 complete tire sets since 2004. See several previous posts. Last ST "E" rated tire lasted 200 miles before belt separation.
Not sure of reason. Two "dealers" who had service shops other than NDRV looked at bearings, axles, brakes, etc, and said all was OK.
2004 30ft. Classic
Hensley/Prodigy
Old 09-02-2012, 01:13 PM   #7
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
Did you ever have the alignment on your truck checked? Just wondering if there were no issues with the trailer, if the truck was a bit sideways...
I guess if the new setup fixes the problems though, then your original checks that said the running gear was "OK" were obviously wrong...
Looks a bit snug though... the tires aren't in risk of contacting the trailer on a big bump? Hard to tell in the picture...
Friday is offline   Reply With Quote
Old 09-02-2012, 01:25 PM   #8
gklott's Avatar
2004 30' Classic
Images: 53
Yes on truck alignment. Have Michelin XPS RIB tires on truck.
We check the Hensley hitch alignment too before starting each trip. NDRV confirmed Hdnsley was ok.
Plenty of space around news tires. I can confirm XPS about 1/2" larger diameter as everyone else mentioned. Will post closer image with ruler.
2004 30ft. Classic
Hensley/Prodigy
Old 09-02-2012, 01:42 PM   #9
Well Preserved
1993 21' Sovereign
For those that want to know, as the tire assembly moves ipward, it also moves backward, away from the edge ofthe fender well. So, if the tire doesn't hitthe fenderwell when installing it, it will not hit the fender well on regular use.
Old 09-02-2012, 03:28 PM   #10
2007 Base Camp
Well, the front one moves away, but the back one moves towards... which is the cause of my first question about 'is there enough room when the suspension is at max travel...'
Old 09-02-2012, 03:42 PM   #11
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Just curious, gross weight on my 2004 Classic slide out is 9,100 lbs. Is that rating entirely based on the axles or are there other structural components of the trailer that you have to take into account?
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-02-2012, 05:29 PM   #12
2007 Base Camp
Jack
The GW is limited by what the axles are rated for... and assume some balanced loading of the trailer. For example, if your net cargo capacity was 2000lbs, and you put that all on the rear bed, you might break the frame. So, upgrading the axles is part of the equation, but the rest of the frame is not necessarily over-rated to handle the weight.
If the Airstream frame/shell/floor was in perfect condition, you'd have a decent amount of over-capacity to work with... unfortunately, this forum is littered with people that have frames bending/breaking, floors separating, water leaking...
I'm often puzzled, because the cheap steel used for trailer frames wouldn't be that much more to build a really bullet-proof platform for Airstream. Outriggers bending/breaking... rear frames twisting or collapsing if they bottom out... just very weak engineering considering how long they've had to perfect the concept.
Old 09-02-2012, 05:34 PM   #13
Well Preserved
1993 21' Sovereign
Jack
Jack, there's roughly 100 pounds per wheel assembly that doesn't get counted against the axle capacity. That's because it is unsprung weight, and is not supported by the suspension. There is also a portion of the tongue weight that isn't counted, but that is a more complex calculation based on how much weight gets redirected back onto the trailer's suspension when using WD systems. Just for the sake of throwing a number out, we can suppose an axle capacity of 8700 pounds.
Old 09-04-2012, 09:06 AM   #14
gklott's Avatar
2004 30' Classic
Images: 53
Originally Posted by Inland RV Center, In View Post
That information was given at "service schools".
Such critical specification information should be available to every Airstream owner - in documents provided or easily available any time on line. Anything else is stupid, old school, and greatly diminishes the product's value.
If taught by the manufacturer, such a specific axle metric must come from detailed engineering design analysis. I find that for such a dynamic load and variable consumer application, allowing only a 7% axle capacity limitation is troubling. As a Ph.D. engineer, I would never design to such small specification allowances given the intended application and advertised life expectancy.
Will call Airstream today and ask for the document that contains this information.
Your service school quotation is excellent information for every potential Airstream owner. Every time we go into our trailer, more pieces of metal, rivet pieces, and other debris fall out, we find more fasteners not properly installed, or see another poor quality indicator. This just adds to the list. With Airstream's terrible 2004 quality, as documented by many posts including mine, Airstream is not the quality trailer as advertised. We all should continue to question Thor's price to value - which your information just seriously degraded.
Bringing all this information, good or bad, to the public is important. Thanks.
2004 30ft. Classic
Hensley/Prodigy
